Even with that mod you wouldn’t get Verum sub-bass amplitude and impact out of a cheap HiFiMan.
After 3-month-waiting, my Verum One finally came back to me with the perforated pads as a gift.
The comfort and the soundstage are much much better on the new pads than the stock ones. They do change the sound more than I expected, the whole sounds seem to be dragged to the bright side a bit at the sacrifice of reducing some subbass. It’s like the Verum One now can switch between Audeze(dark and intense) or Hifiman(laid back and airy) types of signature.
If you want I can make an official thread?
Yes sir! ![]()
Do you have any links to this just wondering?
Yes !
https://www.verum-audio.com/store
You can snip them better if you want I just snipped them as fast as possible xD
Speaking of soundstage vs. FR correction, I’ve been using these with one of Oratory’s EQ curves for quite a while now, and while it does make them seem more revealing, I’m coming to the conclusion that too much stage depth is lost with this method, and it makes them less “believable” and enjoyable. Until I find the patience to do a proper personalized “Griesinger equalization” measurement I think I will stick with some simplistic preset just to help with the extension at both ends of the spectrum, and leave the mids alone. (Hey! Teacher! Leave those mids alone!)
