šŸ”· Dan Clark Audio Aeon 2 (MrSpeakers)
https://soundluck.taobao.com/?spm=2013.1.1000126.2.14331e10FL7IcX
This retailer seems to have most products available on Taobao.
https://jabensh.taobao.com/?spm=2013.1.1000126.2.773314f4OWp5iA
This retailer seems to have more Chi-fi.
https://hifi-roadrunner.taobao.com/?spm=2013.1.1000126.3.1e1f2f8bPfU8tz
This one has imported&domestic audio gear.
Also, on a separate note, if Taobao sometimes has amazing deals, so if you are in China for an extended time, I would recommend searching for deals.
It is up to ~3600.
Thank you for all the help!
In terms of portable, I do see the xduoo xd05 plus
https://item.taobao.com/item.htm?id=601228804341
and the chord mojo
https://detail.tmall.com/item.htm?id=606867888121
The ifi xdsd is also an option which is very nice imo
https://detail.tmall.com/item.htm?id=624506115375
I do see the ifi idsd micro bl, but it is out of your budget at 4380
I am sticking with portables for now, the x05 plus would be the most impactful option, but would be the least refined option imo. The mojo would be the most detailed of the bunch and most refined I would feel, and the xdsd would be a good balance with the most features, also slightly warmer and more forgiving
Thank you for all the help! I think I’ll try to find a place to try out the recommended. If I can’t I think I’ll try to get the Chord Mojo. Have a great afternoon(or night)!
If you have the ability to try out stuff do that for sure, that’s the easiest way to make a decision, good luck :+1:
I just got my closed set back from DCA after realizing that one of the vents had a puncture in the screen material. It had been that way since I got them and I didn’t realize it wasn’t normal.
After not having them for a bit, I really missed these. In the time these were away I picked up another planar. The Diana V2. A cursory comparison: these are not as technically accurate, and lack ā€œfinesseā€ by comparison to the v2. However, I think the fuller, maybe less accurate sound of the aeon is more pleasing to my ear. For certain the stage the Aeon creates is much larger and placement is easier to pinpoint. These are my go to gaming headphone and the fact they’re my only closed can they’re also my choice for isolation.
Just wanted to give a little comparison and say how much these headphones rock!
FYI. Selling my Aeon2 Opens…send me a note if your interested.
Alex
Hmm I’m curious how all these different pads would sound on the aeon 2! I love how comfy the stock pads are but it is nice to have options.
Dekoni has the frequency charts to what the pads do on their site
Cant read charts soo what does it mean for each pad
Did you read the descriptions? They pretty much tell you what they do as well.
As for impressions you probably aren’t going to find any as these are new.
On a side note I love Dekoni and I enjoy pad rolling headphones but I’m not going to pad roll a headphone that has stick on pads unless I have major issues with the stock pads, which in terms of the A2C I most certainly do not. I guess it’s nice to have options when they inevitably wear out but in my experience with this hobby the headphone will most likely have been sold on before then.
Doing a little bit of reading here and I’m curious if the hip dac (balanced) has enough juice for these?
It might, but I think it may sound a bit sloppy or loose imo, it should get them loud enough but if you really push them it might run out of steam imo
I had these with the hip dac, and I didn’t enjoy how it sounded at all. It powers them but it really limited what these headphones can do.
Yeah I would agree, it can work if you need it to but I would really suggest going for something more capable with them
@M0N okay thanks guys
I’m pretty sure I want to try these so I’ll have to figure out a different portable solution. Too bad really. I like footprint of the hip.
In the 500 ish range you could pick up something like a idsd micro bl but that’s way larger, perhaps like a hiby r6 pro might be able to push them well but I can’t confirm if you wanted a dap
I’ve been thinking about going the dap route lately for portable and certain use cases at home. Don’t know Jack about them but I’ll start looking into it :+1:
So I assume the mojo and xdsd are underpowered here as well?
Hmmmmm while I don’t think they would be on the same level as the idsd (in terms of pushing the aeon 2), they would give a pretty solid experience imo, I think the mojo actually might do better as it might be able to give more current to the aeon, but the xdsd is a decent option from my experience with the aeon 2. If you get a balanced cable for the aeon 2, you can perhaps grab something like an ifi xcan and while you would just run this from your phone audio it would power them fairly well. I would also give a nod to the xduoo xd05 plus with a burson opamp, as this does a good job if you can’t squeeze a micro bl, but it is almost as large
