The Hex might be? and they sure look dope…
Maybe 399.999999999999999…. :grinning_face:
What are they trying to achieve with that stupid price guessing game?:thinking::yawning_face:
Perhaps some excitement or engagement…
Yeah Aful’s marketing department…
90 drivers per side! Wooooo! :wink:
ODA- One Dot Audio
Seems it’s $389.99 :man_shrugging:
:nerd_face:
If you’re wondering between this
and this
or this
choose this
:nerd_face:
You’ll thank me later. :beer_mug:
I bet that is one of the most microphonic cables on earth. Can you upgrade cables with the earphone you recommend or are you stuck with that one?
Most cables are microphonic. Otherwise, Senn’s OG cable has the best sonic experience for my ears.
ISN Audio x Effect Audio SORA is officially released.
Driver Configuration:
2 Dynamic Driver + 2 Balanced Armature + 1 Bone Conduction Driver + 2 Micro Planar Magnetic Drivers
Low frequency: 2 8mm opposite placement liquid silicone dynamic drivers
Middle frequency: 2 Knowles Balanced Armature
High frequency: 2 micro planar magnetic drivers
Full frequency: 1 vibration-type bone conduction driver
Premium Stock Cable:
Effect Audio silver-plated copper cable boasts precise conductivity and delivers exquisite resolution in the high-frequency range, revealing hidden details in the music and resulting in a transparent and dynamic sound. The vocals are bright and smooth, giving them a natural vitality, as if sketching a clean and vibrant soundstage for you, bringing a pure and infectious listening experience
Parameters:
Impedance: 13ohm@1kHz
Sensitivity: 119dB@1kHz
Frequency response range: 10~40kHz
Cable: 2-wire UP-OCC smelting process, single material Litz with silver-plated copper central core, 2.5mm wire diameter bundles with EA UltraFlexi ultra-soft sheath
Connection: 2-pin 0.78mm
Plug: Gold-plated
Switch definition:
Switch 1: Control low frequency, turn on to enhance low frequency, turn off to normal mode
Switch 2: Control high frequency, turn on to enhance high frequency, turn off to normal mode
The colour is not for me but that cable looks like it could be extremely easy to manage.
