DDās need 100-200 hours to break in properly. Mine have definitely changed over the time Iāve had them.
I think Iām just going to eat these other tips. They look DELICIOUS
The FD5 is something of a unicorn; they take well to mods (EQ, cable swap and dampening filters) and can be pretty much what you want them to be.
For the low end: the balanced, YinYoo 4 cores 4N OFHC High Purity Oxygen-Free Copper cable takes the FD5 well into basshead territory. On well recorded tunes the sub bass is clean, yet has itās fair share of resonance.
For the mids: most of my IEMs (at best) can address the polar ends of the frequency range, but can be found a little lacking in the mid range. For vocals, I find Dynamic and Planar drivers to be my go to. After the recommended (by rep on Head-Fi) 100 - 200 burn in, the mids are clean (devoid of bass bleed) yet remain true to the artists (e.g. Sinatra, Nat King Cole, Alicia Keys, ā¦)
For the upper range: in stock form, I find the FD5 to be fatiguing, as Iām overly sensitive to spikes in the 2khz - 4khz range. But after a cable swap and my homemade filters, I can now appreciate the FD5 for itās ability to address a broader expanse of the frequency range, than most.
To dial in the FD5 to exactly what I want out of them, Iām using the PEQ, on my Qudelix-5K
Welp, got the DM8 in tonight. It sounds like itās at the $50-150 level :\ Itās no competition at all for this bad boy Iāve got in my ears right now. About to put the copper cable on. Buckle upā¦
But wait, lemmy finish this 28 min Mike Oldfield jam quick, it sounds SOOO GOODā¦
Canāt tell if I like the copper better or notā¦
I do seem to be losing some detail. Depends on how aggressive the song is, I guess. Iāll stick with the silver, I think. I would rather hear all of FD5ās incredible, shining, diamond-like, unmasked details and listen at lower volume when needed.
Every time I put these on and hit play, Iām amazed. If youāre reading this and you havenāt gotten an FD5 yet, you need to immediately sell some of your car doors and buy one. These are the real deal. Iāve never been so impressed with a phone before, outside of my brief time demoing HE6 & LCD-3 like 5 years ago. From the deepest growl to the highest squeak, these amaze me equally across the board. NO weaknesses.
Current burn-in = ~93 hours. Bass tips + wide tube + stock cable.
Well I got the FD5 today
After 2-3 songs Iām picking up graininess in the treble, symbals sound splashy, mids are recessed definitely, itās like they have a veil over them, separation is not the best also.
I canāt say that I like what I hear at all
Thatās with stock tips, cable and V50 as a source
Itās a DD give it some burn in
Yes Iām gonna be fair and give it 200 hrs of burn in, but for now S8F are walking all over these.
Interested to hear the outcome
I donāt know all the products available in this hobby. If the source is the V50 phone I would throw more power at them. They tighten up a bit and the mids start to come out. I apologize if Iāve mistaken.
Could be the dac. I noticed a big difference between my AP80 pro vs DX160 and Q5s THX. Ap80 had more bass and treble.
Edit:
I just listened to them on my AP80 again and they sound bad.
It is the amp, not the dac that is the reason for that difference.
Whoops, I meant DAP.
I donāt own any fancy DAPs or amp-dacs all I use is V50, ES100 and BTR5. I can only experiment with tips and cables after burn in, weāll seeā¦
Iāll be eager to hear of your experience with the BTR5 and these.
After burn in Iāll share my thoughts
The stock cable is one of the best cables that comes with any IEM. I wouldnāt remove it especially being an MMCX.
Yes that is my thought on mmcx I usualy avoid changing cables too much even 2pin. But I think it wonāt hurt if I try 1-2 cables. In addition fiio have provided mmcx tool for easier removal so it should be OK.
I did not enjoy using that tool⦠:\ The shell gets in the way big time, and I felt like the plastic lips had deformed/dented during my 2nd cable swap, when taking the copper off to put the stock silver back on. Not impressed with anything MMCX-related, period. It needs to end.
Agreed. This is why I recommend not to remove an MMCX cable unless you are changing it once to upgrade it, then leave it alone for life.
Fair enough. Stock cable is indeed very nice, it doesnāt handle the best but it it what it is. I agree itās better to leave it be. I had mmcx ports failing in the past.
Just with some 30-40h of burn in sound has started to settle in and with azla xelastec tips and 2.5 connection out of BTR5 there is already significant change for the better.
Iāve seen a few people mention on this forum and others, the outer sharp edges rub against their ear. The same happens to me, and Iām trying to think of the best way to take care of this. Iām thinking of using a small strip of climbers tape just big enough to cover the sharp edge and adhere to the iem. Anybody out there have a better idea? The size of the iem isnāt bad, itās just that darn sharp edge that rubs after a while.
