yeah, I certainly hope so.
Graph wise it looks like a better tape.
I just noticed that the FH3 is described as āDoes come off as sort of a broken FH5, but the FH5 elements are mostly there.ā in crinacleās ranking and its rank is a C+ vs a Brank for the FH5.
Do you guys agree with that description? Most reviewers i watched prefer the FH3 over the FH5 so i was surprised to see this.
I disagree with pretty much all his rankings but I havent heard the FH5 to be able to say if it is better. I have seen as you mentioned, a lot of people (both users and reviewers) say they would take the FH3 over the FH5.
If you wake up in the morning and the FH3 suddenly sounds tiny and horribleā¦
Just remember to return your Android Accessibility sound settings from Mono to Stereo again after sleeping with it on cause you listened to your single Minirig last night⦠
Man, I love my FH3s!
EDIT: Wow whats up with these Xelastec tips?! Fitting is a bit more complicated than the others, but after you get a fit it is like they are freakin glued to your ear canal! lol
EDIT2: For the FH3 the Spiral Dots are fantastic, the winner between these 3 for sure.
yeah, the FH3 match up well with a wide bore tips,
spiral dot, azla sedna, final type E TWS,
I keep coming back to the Spinfits though, just because it is so comfortable. I have my IEMs on 6 to 8 hours per day while working, with the Spinfits i canāt feel them on at all, while with any other including the Spiral Dots i can always feel them pushing against my ear canal.
ooh, please try the Final E TWS, itās softer than the spinfit, most comfortable tips in my collection,
Final E TWS > Sony Hybrid > Ortofon > Spinfit > Spiral dot SF > Final type E > Azla Sedna
I was unable to find these for sale anywhere, but i just checked and they are finally available on amazon! I will grab some right now, thanks for reminding of this one!
After a month with the FH3 I thought Iād update my impressions:
Iāve heard quite a few people mention they prefer the FH3 to the sound of both the FH5 and the FH7 (neither of which Iāve heard). Iād certainly be interested to hear what sort of IEMs people consider upgrades from the FH3, as I feel like there really isnāt much more that can be achieved in terms of sound quality within this particular signature.
Hey all. While I really enjoy my FH3, the shell hurts my outer ear at times so they are not very comfortable for long hours. Also when lying down their weight bites into my ears even more and canāt stand them for long so I switch to my minute MH1ās for sleeping usually. I miss the clarity advantage of the FH3 when I do though, not the highs, the overall clarity. Do you think I could find a similarly signatured iem closer to the size and shape of the MH1? IE 800s maybe? I guess it should be a single DD to be that small. I donāt think I would like BA cause I like a deep, heavy but also tight bass. My ideal signature I think would be like the FH3, same clarity or better, same bass or even bigger and maybe a tad less strong midrange-treble. FH3 is piercing my ears with some songs with specific female voices, especially with the vocal and balanced tips. I can only stand them with the bass tips or foams. I am not sure if I described what I would like very well, sorry for my Englishā¦
I would recommend the Ikko OH10 for both of you guys (2 posts above), definitely more relaxed in the mids and with better bass and much larger soundstage (imo, i am not a experienced reviewer).
They were impossible to wear for long sessions for me because of fit issues, but each ear is different.
Has anyone compared these to the JVC dual carbon?
Can anyone compare these to the ibasso it03? Wondering how different they are.
Fairly different sound sigs. The jvc are more transparent and have crazy slam/dynamics with lesser tonality while the fh3 have better tonality and a more forgiving smooth sound signature. I would say the jvc are more fun if u prioritize punch while the fh3 might be more fun if you prioritize bass quantity (quality still sides with the jvc by alot, much tighter and faster with more slam aboot) also jvc has better detail, however another issue is that the fh3 is easy to drive while the jvc requires decent power
Thank you! Looks like JVC completely outclasses the fh3 in technicalities. Hard decision. Canāt underestimate ease of use and versatility on source.
The jvc is very lean on midbass so the music has to have alot of sub bass to make up for the lack of midbass imo. I will continue to refer to it as ice while the ex800st is fire lol. Both are great and do special things, but they are not complete enough to be the only set.
Yeah for sure, source matters a fair bit with the jvc. I mean itās not like crazy picky nor nothing, just needs some extra power. And yeah for sure I would say it is fairly better int erms of what it can do, altho I know the fh3 tuning is also loved by many so ymmv! (altho the fh3 had the technical abilities I wished the fh3 would have had)
From crinacle: āThe FDX1 is a lean sounding monitor. Not necessarily a bad thing; the lesser mid-bass and lower-midrange response helps with highlighting the sub-bass and is part of the reason why the bass sounds as controlled as it is. Unfortunately this means that the FDX1 is not an IEM I would describe as ārichā, āsmoothā or even āmusicalā, whatever thatās supposed to mean.ā
That description kind of reminds me of the LZ A6, very little mid-bass and awesome sub-bass and as a result mids and highs are clear and soundstage has lots of air. If you compare it to the ISN H40 for instance, which is mid-bass focused, the difference is huge and both has their cons and pros. I think the H40 is what he would describe as āmusicalā and not lean at all.
This JVC sound very interestingā¦
