I totally bought mine off your non-recommendation
Hope youāll enjoy them! Iām glad your decision was based off my non-existant help.
#blameZaphain
Itās a movement.
Yes, shift the blame to someone else
Anyone else having trouble with clamp pressure.
I thought it was just a fitment issue but I realized last night the reason for this feeling is the clamp pressure from the spring loaded cups.
Maybe they will wear in⦠Maybe Iāll get used to it?
They kinda wear in and also you get used to it. The first week comfort was meh but not itās gotten to where itās not an issue for me personally
My Clear Pros just arrived. Firstly, these things are aptly named. Wow. Crazy detail retrieval! They have better bass response than I anticipated and a unique sound signature. I will say, though, the headband hurts my head. Iām currently using a spare headband cushion for another pair of phones. Helps a bit. Back to listening. I am still deciding if theyāre keepers. Strong possibilityā¦
RME ADI-2 Pro > Liquid Platinum > Clear Pro
Also just got some new tubes for the LP! Sylvania Gold Pin D-Getters. They sound awesome!
They get more comfortable as you use them imo, but comfort might be an issue for some, hopefully you end up liking them ![]()
Also nice tubes lol
Iāve been off for 4 days and they have be stuck on my headā¦lol Especially since the RNHP arraived. I hope you like them as well.
I bought about a dozen headband covers⦠this one fits the best and looks the nicest. And gives a bit of extra padding.
https://www.amazon.com/dp/B07K4C4BPN/ref=cm_sw_em_r_mt_dp_U_fqqmEbDBTM5QN
Thanks. I was asking about buying some tubes from a guy on hf. He didnāt have what I was looking for at the time but gave me a heads up on the Sylvanias up on fleabay. He says itās a good price, but I am a total novice when it comes to tubes. I got them for $65. Dude says they go for up to $150, but I have no idea?
I might pick one up for my Grado. That headband as no padding
Those headband covers look cushy. Might have to snag a few. Color me impressed with the Clear. I think it works surprisingly well with any genre Iāve thrown at them so far. I listen to basically EVERYTHING. Except opera and new fangled Country BSā¦
Canāt stand it, but everything else is game for me lol
I donāt find the headband on the Clear that uncomfortable, but after some hours of use I have noticed a hotspot developing⦠also i can see wanting to protect the padding on the headband is probably a good idea, so definitely grabbing one of these, thanks.
yeah for me itās mostly just keeping it clean. Comfort is perfectly fine for me. But it does add a bit of nice cushioning.
I wonder if a ZMF Pilot Pad would fit?
Just ordered⦠Iāll let you know. Lol
