šŸ”· Focal Elegia
I also joined the Elegia club, don’t have enough time with them to give my impressions just yet. Very curious to compare these to my Elex, as that is currently my favorite all around headphone that I currently own.
I’m also curious about your comparison to the Elex. I don’t have it yet but I’m considering it as my open back upgrade. I want to know how it’s different and how it’s similar to the Elegia. That will help me know whether it’s worth it to me to own both, or if I should go after a different open back from somebody like Hifiman or Audeze.
Just got to unbox my Elegia. I can safely say the build quality is far beyond anything else I own. Haven’t had much time to listen yet, but I’m looking forward to it.
Had to grab a pic of that cable: it has a mind of it’s own!
Elegia by Salvadore Dali
Getting not only a good seal, but the ā€œrightā€ seal, was really needed in order to produce proper bass response in my experience. Experiment with trying to get the seal right, I had to basically force the cups to be angled in at the back of the cup. Then they became as neutral as they are claimed to be with precise, accurate, and punchy but controlled bass. They really show off the Focal driver tech once you can get a good seal.
Hmm I wear glasses, so I feel like getting the ā€œrightā€ seal will be near impossible tbh. I still think it sounds great, don’t get me wrong, but getting really impactful sub-bass is something I don’t think I will get from these unfortunately.
Although these seem to seal better than most glasses wears for me. I’ve read that some people can’t get a seal, but I really don’t have any leakage personally. The glasses I wear are quite close to my face, so most of the time I get a good seal on headphones though.
Okay I found some songs that actually kick the bass up in these a lot, goodness. It definitely doesn’t sound as neutral as I previously thought yesterday lol. Really enjoying these.
Also now that I’ve had these for over 24 hours, I must say these pads and the headband are incredibly comfortable. This is easily the heaviest pair of headphones I own, but it doesn’t really feel like it due to the comfort level, which is really nice. However, this cable fucking sucks. It will not straighten out no matter how much I mess with it. Might get an aftermarket cable…
Yea. Like I said, they bring out the bass when the track has it. If you’re really interested in bass use eq. The elegias will oblige.
Otherwise they do justice mostly to what the track intends.
exactly what im finding
From my very limited listening: I’m enjoying folk the most. Vocals sound great to me. Definitely has a great sense of space for a closed headphone.
:smiley: I have two cables on order through Hart, going to be a long wait though.
Yeah, vocals on these are definitely the most stand-out for me so far.
Also @Pr3ssAltF4 I am thinking about getting into using eq. Never done it before, but I think if I could up the bass just a tad, these would be nearly perfect for me.
Yea. I tried it a bit, but I just like the way it presents the bass. If I’m looking for punch or rumble I’ll throw the clears or the eikons on.
If I didn’t have the other two I think I’d still be good with it :stuck_out_tongue:
Percussion on them is my favorite.
That photo really captures the essence of why that cable is hated lol. You should post it over on the funny picture thread
Does anyone know of a relatively inexpensive 2.5mm balanced cable that will work with these? For my ES100.
Looks like maybe a Heart Audio Cable with the 2.5 adapter would be the way to go? Other options to look at?
Yeah I can recommend the Hart cables. I have a bunch of them. Just takes a little while to ship once you order usually. Don’t know if any others off the top of my head. I have the Hart cable for my Elex, I love the interchangeable termination system.
There are a lot of options on AliExpress if you are into that sort of thing. I’m considering picking up this one terminated in 4.4 to use with my Hip Dac:
They have a silver cable but cost more
I ordered two from Hart and other cables as well. If you don’t want the interconnect system James can make them terminate how ever you prefer. Ordered one like that for my dad’s set and will just use a 2.5mm to 3.5mm adapter if he ever needs to plug into a different device.
Periapt makes cables as well other users have said are great, also in US and custom ordered / ship times apply.
They Meze cables mentioned will work but I personally don’t care for the look of the thin 3.5mm connectors with the recess on the Elegia, I want something to fill that gap as much as possible.
