The clipping is starting to aggravate me with certain songs. I can play Fleetwood Mac at 3âclock until my ears bleed just fine but going past 12âclock with half of Daft Punk songs is just asking for bass clipping. Canât wait for my new bass cans.
I personally havenât encountered the issue with an elex I have demoed but if you listen really loud (like too loud imo lol) or try and eq more bass they might perhaps clip.
idk maybe Iâm going deaf or something but I swear I could and want to listen to those songs louder but I canât cause the clipping starts happening. I hope I donât have a defective pair :0
You should use your phone and check and see the volume your listening at with a sound meter app. If your going over 85db, it might be worth forcing yourself to get used to a bit lower listening levels, just to save your hearing. lol
So that driver i took out of the elex to replace works after swapping in the magnet I had on my wall. haha.
It could have very well just needed to be cleaned up a bit, to get it loosened and free moving too⊠but I figured to swap the magnet, since I was taking it apart anyway. Works perfectly now. Extends fully into the low end as it should and sounds right.
You seem to be so handy with these headphones! Any opinion on modding the focal headphones to have swiveling earcups? Or even some kind of modding to put the âspeakersâ onto a different headband altogether?
Have you ever measured how loud you listen? I bought a cheap audio meter from Amazon because I thought I might listen too loud. Turns out my average range is 65dbâs to 75dbâs with the odd bump into high 70âs. But I never go past 11:00 in low gain with anything.
Thatâs a good range to be in
I have tried a free app on the phone, what the best method A, B, C or Z weighted?
Iâm okay⊠just dumb enough to open up and mess around with expensive headphones. Lol
I modified my Clears a bit.
Unfortunately, the headband is pretty stubbornly designed. Itâs not friendly to modification at all in any sort of non-destructive sense. The monoprice Monolith m1070 and m1570 appear to use the same headband though, with different padding, so maybe if you could figure out where those are sourced. Maybe check Ali Express.
I have no idea. I just ordered this:
https://www.amazon.ca/gp/aw/d/B07K1SN4MC?psc=1&ref=ppx_pop_mob_b_asin_title
Then I cut up a piece of cardboard wide enough to cover an ear pad and cut a small hole in the middle. I put the tip of the meter through the hole in the cardboard and measure the sound.
Not sure how scientifically accurate it is, but I find it interesting. ![]()
Ah I seeâŠso Iâm guessing those go into swiveling speaker housings? But would those housings hold the drivers from the Elex?
How do these compare to the AKG 712 pros? would it be an upgrade from? or just different all together
Pretty good upgrade imo. They might sound a bit more intimate at first comparing to the k712, but they actually do extend out just as wide, but only do so when the music suits it. I think the elex is a bit more neutral but still somewhat slightly w shaped for sound. I think the elex is more detailed and has better spatial recreation than the 712. Also the elex has better dynamics imo. Overall I would def pick the elex over the 712 for myself. Also the elex is a bit easier to drive as well
Do companies ever do silent revisions where they replace the wires?
Yes, but if itâs the headphone cable I donât know if I would call it a silent revision
No, i think you would want to stick with the housing designed for the driver. The acoustics are very important to the sound.
How long do pads usually last, and how long would you expect the pads for the Elex to last?
It depends on the pads and how clean you are when you wear them lol. I would say for focal most likely about 1-2 years if you daily drove them
