Is this getting out of hand?
Is that a rhetorical question?
whatever happened to your headphones cases?
I don’t see an issue here
Maybe he has a pile of headphone cases elsewhere.
And technically, yes, because you can’t hold all of them in your hand(s).
Those cases were for transport only. Besides cases are not a good solution to this problem. Maybe i need good cheap stands.
Then things would start getting out of stand!
That would most likely help
I hear cases can also be used for storage.
You need a storage solution but things are looking a-okay otherwise ![]()
But if i dont i might get banned
Step 1: Find a box big enough to fit all of them.
Step 2: Put them all in the box.
Step 3: Then send box to me.
I’ll worry about the storage.
I wonder if since drop is using a he60 in the picture if they are hinting at a he6x, that would be pretty sweet. After getting an adapter for mine they are just awesome
Thanks! i got a box right here… Hey waitaminute!
I said cheap FBizzle. Cheap is the keyword
I was thinking more a HE5. I dont have a amp. wouldnt it be cool if they made a HE6 that could run of a regular hp amp?
So you can spend saved money on more headphones? ![]()
This is talking about Sennheiser not hifiman, the he60 is a senn estat
