PC --> DAC (usb)
DAC --> THX Amp (XLR)
THX AMP --> GS2000 (your new XLR cable)
No not a dumb question at all, I probably have no idea what I’m talking, but here’s what I think:
Normally I’d say yes, a fully balanced amp typically has two discreet circuits, one for single end and one for balanced, and typically manufacturers have the balanced circuit in mind and the single end is like an add on. So in order to fully utilise the balanced circuit you do need balanced in from a balanced DAC.
However, in your case I believe the 887 is more like pseudo balanced, meaning that the balanced signal is converted from its single end circuit (I think, assuming it uses an almost identical design as the 789) so some say it doesn’t actually matter.
I’ll leave this as a question here and let someone who knows better than I do answer your question more properly.
3.5 unbalanced? Yeah I strongly doubt you’re getting the power they want.
On second read, now I realise you’re asking whether u can connect the amp directly from your computer (USB). The short answer is simply no and it has nothing to do with balanced or not.
Your computer USB (or coaxial, toslink) emits digital signal, and your amp takes analogue signal. Hence you need something in between, a digital to analogue converter (DAC). The easiest way (Altho probably a bad way) is your computer line-out, which already has an internal DAC converting digital signal to analogue signal. But usually it’s not decent so you would probably want to buy a standalone DAC.
Then you will think about how to fully utilise the balanced output, which I’ve replied above
I’m going to use the Monolith as a DAC and AMP.
I’m sorry, its not the 887. Its the Monolith 124459 to be specific. I’m going to use it as a DAC/AMP.
In that case you should be fine to just plug the DAC/AMP in using a USB from your computer and then use your headphones with the XLR out on the front. As long as you use the GL2000 with a 4 pin xlr cable at the end.
Ah ok. So PC -> USB -> Monolith -> XLR Balanced Cable -> Headphones will make them balanced. Got it. I thought it required to use the XLR inputs in the back somehow to get the balanced sound.
Nope, the DAC inside handling your USB input will drive it balanced. Hope that helps!
Edit: Also yes, that signal chain looks good to me!
Ah yes then USB straight to the DAC/amp combo. I believe the XLR input is for when ur using ur Monolith as a standalone amp. I almost forgot this combo unit exists
The dude from the headphone show said in his review that Sundaras were better in many regards.
OK it’s official. These are now officially my favorite headphones for punk, ska, Dio/Rainbow/old Sabbath, Thin Lizzy, Doobie Brothers. I could go on, and there’s definitely a lot of music I don’t like them with unless you EQ them but some just sounds how it should. Oh, and I really like them on tubes. I never really actually liked tubes before but I’m really feeling the way these sound on tubes.
comparison please,
thank you so much,
Did you damage them?
did it break?
and the magnet only on one side?
Yeah trying to put it back together my fingers slipped into the film.. I was trying to use clamps the the magenta are crazy strong.
Blockquote
That hurts.
To be honest I’ve been depressed lately, and it almost doesn’t seem real… But it’ll kick in when. I have to buy another pair… I contacted lionson… hopefully I can just buy the driver…
