🔶 Grado Ltd Edition Hemp
For purely selfish reasons I would say get the RS1e. Also there is a buy/sell thread.
Does anyone want to trade? Lol
I’ve finally come to a conclusion about these pads in the Hemps.
They are good. They don’t sound worse is any particular way other than a little worse imagine but with a slightly wider sound stage. They add more treble but not too much and they “clean” up any possible “bloat” in the lower mids and upper bass (if you don’t like the lush sound of the Hemps). If you want a slightly brighter and less lush sound with a more over-ear fit, these are great.
I’ll be sticking with the stock flat pads though. I love the way the Hemps sound with the stock pads. I’m glad these pads are good since it means more people might be able to enjoy the Hemps with the different sound and fit, but I only got them to experiment.
I received these last week, since there were a couple in stock on Amazon. I actually just wanted to try them and return them, but I’m not going to. I’d been curious about Grado for quite some time, but I was put off by reports of their anaemic bass. The Hemp definitely doesn’t have this problem; the bass is more impactful than I was expecting, especially as an on-ear headphone. Guitars sound amazing in rock and most “lighter” forms of metal. Now I want that effect in all my other headphones!
This is a good set for poor recordings, it doesn’t seem to care too much what you give it.
Comfort is better than I expected, but the attached… garden hose is a bit silly. I can live with it for the sound, though.
These are very different from other grados. Very different and the best Ive heard
They are great. I really hope they turn the Hemps into a regular model like they did with the PS500e which was originally a head-fi limited edition. This is a tuning they should really keep around.
I hope they do too. A lot of people like them a lot by the looks of it.
Zeos hype train incoming!!!
I agree with how great he says these are and “creamy” is a good way to describe the sound in a word. If you are ok with possibly having to mod a bit or are willing to put up with the problems, GET THESE!
But speaking of the problems, I don’t 100% agree with the Z man here. The rod blocks are not fragile. Not only have I not seen many (if any) reports of them breaking, but my own experience is that, even when actively trying to break them using a dead blow mallet and a screw driver, they don’t break easily. The only problem with the rod blocks as they are now is they will over time (years) get loose and not stay in place and they are a little ugly. I also don’t really agree that they should revamp the headband design. As it is, it’s simple, effective, and very light weight. The only part of the headband that really NEEDS an upgrade imo is the plastic gimbals. Starting with the SR325e and up, they should really use a downscaled version of the metal gimbals they use on the 50mm driver models (GS1000e and up). Also, the stock pads on the Hemps are just fine imo. They are not great for long term comfort, but they are a big part of the sound and good enough once they have broken in. If you get these, love them, and feel you NEED to change the pads, the geekria G-cush pads (these are what Zeos used in his review) are a great option for a kind of over ear fit, but the best I’ve found so far are the geekria hole punch flats. These are a softer foam and keep the sound very similar to the stock pads but I still find the stock pads to be better sounding. The Geekria pads just loose a little something imo.
@ZeosPantera if you love these as much as you seem to, I would recommend you check out Shipibo audio. He makes aluminum rod blocks and gimbals and they are wonderful. They make my Hemps feel like the best built headphone I own and you can lock the rods in place to keep your hight and prevent the infinite spin.
Why is the Hemp review by Zeos not listed on youtube?
Maybe it was for Patreons and HFGF first :man_shrugging:t2:
That explains it.
Hi Zeos. You enjoy them very much, but where does it rank in terms of technical performance? Obviously enjoying music is the main thing about them, but I don’t want them to be too underdetailed
this pleases me, i have the Vever G’s for my 60’s will absolutely try them on my Hemps tonight, headslap as to why i haven’t done it yet
They certainly aren’t as detail oriented as some other headphones, but I have not once thought that I was missing out on parts of the music. In fact I was probably paying more attention to the sound just because of how it is presented. Listening harder so to speak?
I may have done a thing. One of the Yolk’s snapped when I removed the cup. I was prepping to do a cable mod and once that snapped I had to think of a way to keep using them. So I destroyed an unloved set of HiFiMan HE300 and Hot-Glued the G1000 pads to the inner plastic rings then fastened them with wire to the Hifiman Yolks. Now I can just pop the Hemp Pods in and out. Still need to do the wire mod but I can say this system actually works prett well. Much more secure feeling then the stock grado design.
not sure it will catch on tho…
That is a true abomination, but it ain’t stupid if it works. Plus now you have all the more reason to get the Shipibo parts.
words of a madman
and this is just sad…
holy shit lol
Oh, I also forgot to mention that the Shipibo parts actually make the Geekria G-cush pads fit more comfortably. The gimbals have a more angled connection to the rod so you don’t have to bend the headband into that square shape to get the pads to sit right on the head.
LOL
If it’s broke then fix it :+1:
