I have said this for a while but angled pads need more clamp⦠I had wondered why beyer didnāt use angled pads on the T1 for this as well since the T1 uses angled drivers and a hefty clamp, sometimes I just have no clue when it comes to design.
Thanks again for the loaner here Pokrog, I will give it some time but this may end up in my collection later on
If youāre a sucker for imaging and placement like me (and Iām pretty sure you are lol) I really think youāll be shocked by how much of a difference it makes. And itās like the cheapest one out there. I donāt know what your usual DAC is but both the i2s and coax out of it are pretty substantial leaps on everything Iāve plugged into it.
I will be honest that I have my doubts such a cheaper unit will benefit me personally, but I am for trying out new things.. as it may help improve my chain later for potential upgrades.
My chains are usually with the bifrost 2, soekris, or some other much higher ended dac around the $600-$1,500 regions.
Yeah Iāve had people tell me itās quite an upgrade on a BF2 (though Iāve never owned one) and on a 1541 I had for a short while it made a pretty appreciable difference in staging accuracy and bass precision. I noticed a lot difference on anything with i2s like the Gustard X16, topping d90(akm), d70s, a spring 2 KTE I borrowed for a couple weeks, and a couple others in the $1-2000 range, but moreover the upgraded model of that DDC, the CMD-17 with nicer clocks is an absolute steal for the ~$130 they cost (liked it much more than a Singxer SU-2 priced at like 3x the cost). If you have a LPS it can plug into and a short i2s or coax cable it can make a pretty crazy amount of difference depending on how your chain is set up.
I mean, if it improves it alot⦠I will just upgrade it in that case. I will sit down with it when I get a chance. Though more concerned about alterring the sound too much I may upgrade to a more neutral sound with a ddc
Think it is about a digital-digital converter. Read at several places that Pokrog says that many USB inputs on DACs are not well implemented and even with this cheap USB to coaxial converter the sound will improve.
Iāve just been reunited with my Focal Elex. Iāve been amazed yet again with them.
Focal Elexes/Clears are⦠pretty darn good.
XS are great headphones, but just another addition to your arsenal at this point.
Canāt go wrong with buying them - canāt go wrong with not buying them.
The XS are probably like tower speakers - a bit distant in some elements. The Focals are like bookshelves - bit closer, and more detailed and more intimate. Though the XS have a much bigger stage, Focalās imaging keeps them quite comparable and competitive.
For dynamics though, Focals canāt be beat.
TL;DR: All things considered, I feel that the Focals are a step up here.
Your.. quite the doubtful one huh. I suppose if that helps you cope with not upgrading anything in your setup by all means.
Gave it a shot. I wonāt say it was a dramatic difference but I definitely can hear a change in the sound.. Not bad either, I will check an upgrade on this later
many will not agree.. also that dongle dac hardcore depends on what your trying to drive to begin with.. its only good for lower impedances that really donāt need much power at all like at 32 ohms but it also definitely depends on the sensitivity too
For those complaining of planar crinkle:
So after complaining I had the planar crinkle, I think the issue has to do with the headband instead.
The headset is a loose fit, and moving my head is causing the left swivel part to make some metallic sound. I noticed that moving the right can put pressure on the headband and made it create some metallic tick (this happen with headphone off too). Currently considering putting some like grease on the head band, to see if it can reduce this.
I wouldnāt be surprised if all the reports here relates to this
ā The Lightning to 3.5 mm Headphone Jack Adapter is designed to transmit audio from the iPhoneās Lightning connector. It contains a digital-to-analog converter that supports up to 24-bit/48 kHz lossless audioā
