There are plenty of more expensive earbuds:
DQSM Turandot
Astrotec Lyra
Somphonio Dragon 2/3
DQSM Turandot
Astrotec Lyra
Thanks! Do you know of any good ones in the $100 range? I know someone who might be interested since they canāt do in ears
I think moondrop makes one as well right? The chaconne
And ve makes some higher end ones too
I havent tried any in the 100 usd range unfortunately. But you can check my database to see which ones I have.
Here are some examples on buds I heard is good from others:
Smabat ST10/ST10S
Kās LB
EDIT: I actually forgot about the Moondrop VX Classic, it is 60 usd but It doesnt sound better than my other 10 usd buds lol.
Yeah they do have that.
But I got the shiroyuki, Nameless and the VX Classic and they are very overpriced.
So I assume it is the same with the Chaconne. (paying that much for something without a replaceable cable is a deal breaker for me too.)
Iām interested in the Etymotic ER2XR but I couldnāt find a thread for them, so Iāll ask here:
How does the level of isolation compare to the Mee Pinnacle PX, with or without triple flange tips?
Do they protrude too far from the ear to be comfortable to wear underneath noise cancelling headphones?
How low is the bass extension? If you use an app like Frequency Sound Generator on Android, what is the lowest you can hear below 30hz?
How is the sense of impact from the sub bass?
Anyone tried putting a foam tip or a hole punched foam earplug on the body of the unit behind the eartip? If it works this could be a good way to further increase isolation, but Iām not sure if it would be comfortable with the angle of insertion.
What types of tips deteriorate over time?
Foam tips do. I havenāt had any silicone tips deteriorate thus far, even on decade old IEMs.
Okay, Iām listening to the ER2XR, and using an online tone generator, I can hear the tone from 15Hz to 15KHz. Thatās probably the limits of my hearing, because that is usually all I can hear with other IEMs.
Especially Comply Foam tips. I think some foam tips last much longer than others (I think Shures last quite a while).
Thanks!
15hz seems exceptional. The lowest Iāve ever heard is the Moondrop Kanas at about 17hz, and thatās a very bass heavy model.
Anyone got any reference IEM recommendations for below £200? so below $250?
Tanchjim Oxygen (210 usd during the next aliexpress sale)
Etymotic ER2SE/XR
I wonder how many misinterpret the feel of bass at the low end as sound.
Does anybody have trouble getting silicone tips to stay in your ears in general? For me, my right ear I can get silicone tips to fit easily, and for some reason no matter what Iāve tried thus far, I canāt get anything to work for my left ear.
Thatās probably because you need a different size for your other ear. Has happened to me.
Iāve tried bigger and small for the left ear and still nothing stays in.
I would take a look at the Azla Xelastec ear tips. I found them very comfortable after a minute or two when they warm up in your ear and they have a more āstickyā feel to them. They stay in my ears even while talking or eating something which always causes tips to fall out of my ears. The Xelastecās are a wider bore tip though so not sure what you prefer for your tipsā sound.
I second the Xelastec ear tips. They are sticky and also conform to your ears with body heat. There are 6 sizes, and you can get a three size pack like this. https://www.amazon.com/AZLA-SednaEarfit-XELASTEC-Pairs-Size/dp/B08BRBT4W7
They are quite pricy though.
