Shozy are thankfully hybrid BA and dynamic with 100 SPL so I think SE is fine
Yeah, although It also depends on how powerful your source is.
So…what are we buying during this aliexpress brand sale event
Guys, I really find it hard to get back to my T2s ever since I got the Starfields. I guess this is just normal for a guy like me who likes a neutral sound signature. I’ll still keep the T2s though since the cable that I have for it now is much better than the last one, and the sounds from these are still good but not as good and improved as the Starfields.
Going to use my T2s and BL03s for today since my Starfields needs a break after all.
Tin Hifi P2 releasing soon?
I hope the P2s will be an improvement from the P1’s already excellent sound.
Most here hope so too, me included. It probably will be e technical problem to enlarge any bass fundament with a driver like the one in the P1.
If you EQ the P1 the bass is very good. So I do hope they can tune the P2 better, because the driver itself is very capable.
P2 better fit pls
Looks like it does have better fit.
CVJ CSN a cheap 5BA + 1DD and a pleasant surprise. Punchy sub bass and treble that has some sparkle. It is very close to the TRN VX in build and probably from the same OEM.
Do any of you guys have any recommendations for ER2XR tips?
I recently put Final E tips with their nozzle adapter. Works pretty well imo.
Maybe this will help some.
Two totally different sets from the same manufacturer…Can you love them both equally?..Campfire OG Andro’s, Forza hybrid cable and spiral dots…Vega, OE cable and Spinfit’s…the answers is a very big yes
…All off of the iFi Micro.
Kinda hard to come by now so maybe worth keeping an eye on these if you’re UK based?..
Guys do you know any case where I can put my IEMs in? I am thinking about getting a watch case to put all of my IEMs in it and it seems pretty neat to look at.
Storing it at home?
I use this:
Although I should have went with a bigger one though
like this one: https://www.amazon.co.uk/dp/B07JM5Y8XT
Yeah that one, though I would need like a portable version of it as well. Just in case I got insane enough to take all of my IEMs for a daily use while traveling.
