Yes it is. There are already some reviews on youtube and other audio reviewer websites.
How are they? It seems that one is best for bassheads from what I am seeing so far.
Yeah really curious if itās good or not, seems like something like that would be super hit or miss
I donāt really know bcs I donāt have them and I didnāt watch the reviews, but here are some reviews on YouTube.
- Prime Audio Reviews
Is this a basshead IEM? | Tin HiFi T5 review! - YouTube - Super* Review
Tin Hifi T5 REVIEW! The latest, but the BEST? - YouTube - The Honest Audiophile
Tin Hifi T5 - Best T series yet!? - YouTube
Nope, doesnāt ship to Croatia
Oh right, yeah they are not for me. Apparently they are too bassy and I am not really a fan of IEMs or Headphones with too much bass. Iāll skip this one.
I have the Noble Audio Sultans for two weeks on loan⦠first lets just say for $3k IEM Iām not that impressed. Iāve never been an iem guy as frankly I donāt like the feeling of having something jammed in my ear canal to get a seal and these bastards are uncomfortable regardless of tips. In the future Iāll just stick to entry level iems, full size hps, and 2 channel.
Yeah that can happenā¦HPās = Hot spotās, Clamp force, Weight, Pad contact issues, etcā¦IEMās have similar issuesā¦some work for you. some donāt ![]()
$'s donāt always = comfort or work with your sources (synergy) etc, that rings true through and through with this hobby lol.
What source did you end up using with them?
Personally I wasnāt an iem fan until recently when I found the right tips with my Moondrop SSRs and also my graces which are now my favourites overall
Iāve tried directly from iphone, from FiiO x7, and from my HP setup Holo Spring KTE ā Holo Mammoth KTE (pentacon adapter). They scale a bit with better sources but itās not a great deal different.
Fitment is an issue just like hotspots but with that aside I just donāt think the SQ is all the impressive per $ invested; just my initial take. Iāll see after a few weeks if they get any better after I get adjusted to them.
Fair enough, tbh Iāve not heard lots about Noble audio stuff. If I was to look at that price range of IEMs Iād be looking at something like the Rhapsodio Infinity Mk2s, but Iām a while off that sort of price range personally
You need to tip roll, getting a good pair of tips is essential to get the most of the iem you are using.
I guess that inverts some whatā¦low $ Iemās totally destroy low $ HPās on everything audio imhoā¦Mid tier thingās get a bit more complicatedā¦sound stage vās detail and imaginingā¦higher tier suff then itāll come down personal sound presentation preferences and your systemās synergy with your HP and IEM sets.
Honestly Iāve heard similar opinions from those who have tried the sultans as well. It looks neat but personally noble for me at least hasnāt really put out much with a compelling value proposition, but I havenāt heard the sultans yet so canāt comment there. Curious on your longer term impressions though if you continue to listen ![]()
Also yes try out other tips, that can really help both fit and sound, but if you canāt stand having something in your ear iems just donāt make sense lol
you guys have some favorite tips that you use as suggestion that I can go put in an order for?
Top 3
Final Audio Type E
Elecom EHP-CAP20
Radius Deep mount
The rest are in my database if you are interested.
I will add that for me no 1 for comfort is the Xelastec, no 1 foam is the tripowin grooves one. Also for sound the epro horn shaped tips are good as well, adds to the mids/vocals. I like alot of the same ones listed above too.
Would be awesome if you could throw in your own data in those FR comparison tools to compare. Iāve been playing around and I think my preference would look something like this:
I want the FH3 and the FD5 to make a beautiful baby:
- The cable of the FD5
- The vents of the FD5
- The shell of the FH3
- The subbass of the FH3
- The bass of the FD5
- The mids exactly between the FH3 and FD5
- The treble of the FD5
EDIT:
And of course a 2-pin ![]()
Thanks all for the suggestion⦠I have some Final Audio Type E tips coming in this weekend so will give them a roll.
I also tried all the tips that came with the Noble and none worked for me (probably a dozen types). So I went through all my TWS ear buds and my cheaper IEMS and trying those tips now. Getting much better results and a better seal (although not perfect).
It does seem that the stems on the sultans are extra thick to mount the tips so itās literally stretching out the silicone. I have rather small auditory canals so this is a bit problematic for pure comfort.
Needless to say for $3k itād still be a pass for me to this point again only 24 hours in.
Also thinking about picking up one of these to test with the xlr outputs on my amp⦠I assume this will work with the standard 2.5MM balanid termination on the sultans.
Wait until you get better tips before you come to a conclusion with them.
Radius deep mount or Azla sedna earfits are probably the best tips when you just want the damn thing to seal.
