Just got the SMSL SU-8 DAC!
Can you get a schiit magni heresy? That sounds super close to the atom with more power
Yes, it is 130€ + shipping - click or Ā£110 in the UK - click
So this Heresy is better than ā€œnormalā€ Magni?
Yes, much better than the 3 imo
Your next step will be to realize headphones can sound as good as the speakers you already have. :stuck_out_tongue:
What does apodizing do? I left mine on that.
If you look in your manual for the su8 there are some graphs that show what it does to the sound. I don’t think I can explain this one in simple terms lol
Lol! Hopefully I didn’t chuck it.
WAY!!! Better than the standard Magni 3
When I download this driver its a word doc. No drivers on the smsl site are zip files on my end. Tried other sites just to see if it was my pc acting weird and other sites work fine. Odd…
I don’t know what did you download but here is direct link for Driver - Click
Yeah. I got it working. Used winzip. Stupid mistake. I could see it too but when I would download the driver it was a doc.
I’m just curious if anybody has heard the SU-8, D50S and Enog2 Pro and can do a quick comparison? Is it even worth it to upgrade past this price point for Delta Sigma DACs? I have the Enog2 pro and wanted to see how it compares to the SU-8 and D50S…
I think the enog 2 pro is actually the best sounding by a slight margin lol (when balanced). The d50s is the best preforming with unbalanced, and the su8 just has lots of features. So for highest quality, the enog 2 pro is my pick, if you want the most features su8, and if you have unbalanced d50s is the pick
If you really wanted to upgrade I would recommend looking in the 500-1k range imo for Sigma Delta
I know I asked you this previously re the 750-1k range, but do you rate the VMV D1?
OK, so now we’re talking SMSL VMV D1, Topping D70, Topping D90, RME ADI-2, Gustard X26, Chord Qutest…any other contenders?
I think those are all solid offerings for sigma delta more traditional dacs, yeah I think you would want to jump to that range
Pretty nice, but honestly I do prefer r2r or multibit in this range
the Cord Qutest is about 1700€ in europe
what price do you us guys have to pay?
Around 1700 USD
Does anyone find their unit so be over sourcing their signal? I find I had to lower my volume in windows and on the DAC quite significantly to get any sort of movement in my el amp’s volume. Distortion would creep in well before normal listening levels otherwise I found.
