This is the official thread for the Koss KPH30 Wireless
- Type: On Ear
- Amp needed: No
- Open Back
[Reviews]
Z Reviews…
I hope they come out with a white-colored one.
Why do I want these so bad but have almost zero use for them
Because Koss. I feel the exact same way.
well dang, I want these too! ![]()
but daaamn, they’re $102 after exchange and shipping!
USB C praise be lmao
might have to test them vs AKG 361BT
yes. as soon as I saw that I knew I had to get one!
Does anyone have any pad suggestions like the original kph30? Like the giant grados?
heard yaxi replacements were supposed to be a solid choice, don’t think grados work unless you’re willing to cut them (zeos did it in a vid at one point)
To my knowledge, Zoe’s cut the pads because of the wire placement. But these being wireless, they shouldn’t have the same problem I’m assuming? I do know about Yaxi, but they are still very much on ear which I can’t usually stand for more than 30 min. With the giant Grados they could atleast be closer to over ear.
my bad thought you meant for og kph30
I still haven’t seen any 3rd party pads for the wireless, shape is a bit different and bigger so not sure if the big grados would fit or not
Dang that sucks. I guess I’ll have to wait alittle longer for some 3rd party stuff to come out. These seem like no a brainer aside from the on ear, that’s my only stipulation. The giant grados made it seem viable.
saw someone say greekia grado pads worked on theirs so I ordered some dekoni grados to see
although a massive pain to get on, grado pads do fit
Grados fit, pain in the rear or not, they fit. How’s the comfort?
for me loads better (especially with glasses on) could probably wear them all day
with the elite velour loses a chunk of bass, goes from a bit muddy sounding to a more neutral balanced sound
Did the elite velour pads add a significant amount of weight? Looking at them right now on dekoni They look like they would awkwardly weigh down the headphone. Although the top comment on them is someone using it on the kph Wireless and loving them. So maybe I’m just reading too much into them.
not enough to make a meaningful difference, weighing feathers basically
