jfc soon weāre all going to be guilty of creating abominations in pursuit of good sound.
now this abomination sounds exactly like if the KPH30i and my Focal Clears, my two favourite headphones, made this:
And i fucking love it.
Has anyone tried Yaxi pads on Grados? I know they have those purple ones but apparently they made the hole too big so the slip off all the time.
Yes, I mean after discovering the BLON BL03 and I think those are on the warm side, I wouldnāt mind owning a set of headphones like the Koss KPH30is that are on the Warm sound signature spectrum. Sometimes you just need something to put in your head to just chill and relax, for too much brightness and neutral can become mundane. It is good to try some other things.
These mods are awesome haha
so, with all the different pads tried on the KPH30iāsā¦which did the best job?
I think its a flavor thing above everything else, my suggestion?
Buy 3 pairs, One stock and 2 modded, that way you can change to what ever you are feeling that day.
Now I have to try this with my extra clear pro pads
Iāmvery tempted to quarter-mod my Yaxis for more treble⦠on this or the Porta Pro.
I like Yaxis because they are relatively low profile, but after messing around with an EQ I really miss having treble extension
Try the Grado pads before tearing into the Yaxis. Doesnāt matter which brand (except for the <$5 ones). If you like the close fit of the Yaxis then try the L Cushions rather than the Gās. I think these are the L cushions anyway.
itās a fun little experiment, nothing more, nothing less. Iām looking forward to your results, i definitely have heard worse.
sometimes there are just people out there who just prefer absolute sound goodness than aesthetics, and I am one of the people for I cannot even the freaking headphones while I am wearing it anyway and I am mostly focused on the music I am listening.
I donāt mind turning a KPH30i into a monster, but my Porta Pro goes everywhere. Has anyone measured the diameter of the grado L? It looks slightly larger than Yaxis from what I can tell. Yaxis are around 60mm. Maybe I can try Plantronic Supra pads.
I guess Iāll mod the taxi Yaxis I have once I get a 5 pad set. These are already losing their color, so they should be fine to ruin in a couple of months :^)
Iād also like to try multiple variations of Kramer and see if more or less holes make any difference. I have 4 outer and center only for now.
@Not_Daijoubu I did a ānickel modā on yaxis on Portapro. Did regain some treble, bass seems a bit less boomy, and of courseā¦more comfy.
Huh, thanks for the response.
I do wish I could find well-consolidated documentation on pad mods for Koss like there is for Grados. Everything is scattered on forums.
The Grados are about 0.3 inches wider on the inside than the yaxi pads, but they fit the KPH30i just fine. Theyāre only loose on the KSC75. I donāt know how wide the actual pad is though, I only have the G cushions which are bigger than Hifiman pads.
They look very nice.
Welcome to the forum.
@JustaDude Welcome! Love the creativity. Howās the sound?
@TimpTim44 Thank you! The bass has increased, as well as the sound stage has become quite impressive, treble is just below sibilant, but only at high volume. Mids are still pretty boomy so not much improvement there. But thatās probably just the nature of the drivers, they are pretty affordable cans after all. All in all the sound has improved, but more so the comfort.
