Reason why Iām returning my 30i, less impressive than the 75 and they donāt really have a use for me anymore.
more on the Yaxi pads, could anyone share how to clean off darker dirt safely? Wiped my red side with wet cloth and its transferring the red color but the dark dirt stayed.
So, Koss PortaPros wireless exist, with AptX⦠![]()
But I guess it would be stupid to get the wireless version when the originals are half the price, and legendary for their sound, heh.
(Even if the sound apparently doesnāt change at all on the wireless version ā good).
Not sure. Perhaps soak in cool or barely warm water?
Iād agree with this. Awesome picture!
thank you @Rhodey
Since the foam is dyed youāre going to get bleed regardless. I use warm water and dish detergent and hand washed the dirty spots and air dry the pads. I notice the pads desaturate quite easily especially the red pads with casual use. I might just end up throwing them into a net and throw them into the washer. Iāll let you know what the results are when I do.
Probably not the ideal place to post this question but Iām not quite sure where.
I ordered the Yaxi pads about a month ago, but I really donāt understand the tracking info they gave me. As far as I have managed to find out itās still in Tokyo somewhere but they keep saying returned to sender. Anyone who understands this?
It looks like they couldnāt find your address. Iād shoot them an email with the screenshot of the tracking info you posted here.
I should clarify that I do not live in, or anywhere near, Tokyo. I live in The Netherlands :P. They (Yaxi) send me a copy of the document from Japan post which has my correct address on it (unless they coudnāt figure out that āNetherlandsā is āThe Netherlandsā).
But yeah Iāll probably mail Yaxi again then. I was hoping maybe I didnāt understand correctly and it just hasnāt left Tokyo for whatever other reason and they are now sending it my way
I know in the U.S. āreturned to senderā is when a package is refused/undeliverable. Perhaps the post mixed up the shipping and rather than international it went domestic. Iām not sure, but hopefully Yaxi will have a better answer.
Good luck.
Thanks man, I send them a message.
Thinking about getting a pair of these to use when out walking.
Just wondering if there is any difference between the classics and these? Anyone had any experience with both?
No difference, just the color and possibly an in-line mic!
Agreed, the color way and possibly a newer mic. Great headphones.
I definitely recommend getting the Yaxi Pads. Theyāre available direct from Yaxi jp, or usually via Amazon.
Cheers!
OK thanks @creaturekyle and @ValentineLuke. I probably will look into the Yaxiās eventually as well, only heard good things!
Theyāre only $25 dollars now, Iām buying 2
dang bro sniping my post like that smh
(Iām kidding)
