My blue ones are supposed to arrive today, and Iâm doing the same on both my PortaPros and KSC75s
How did you get your cable modded?
I didnât. But Iâve seen that you can put mmcx sockets in. I might try.
If itâs not a mod cable then why does it look like fabric? Also why are the drivers and switches red?
Thatâs the cable and colors it came with. There are a few models it seems.
Is that cable nicer than the usual koss stuff? And if so, could you link it?
I checked the internet to make sure that itâs not a fake Porta pro. It seems itâs legit, the only problem I have is a channel imbalance (Depending on the source itâs more or less prominent)
I remember there were a couple of Special Editions a few years ago that had a cloth wrapped cable. Pretty sure that color way was one of them. They also ha White with that cloth cable.
There were several limited color ways tat were European exclusives. I shouldâve bought a pair of the white.
If you look on eBay you can still find a bunch of those colourways for pretty cheap! Braided cables and all.
Two weeks after using these non stop with the iBasso DX160 and RNHP. My Iems are gathering dust. The Porta pros arenât technically a marvel but I donât care, everything sounds so enjoyable, specially old recordings that I listen twice as much music as before. Ksc75 and Kph30i ordered as well as a second Porta pro.
Itâs a great headphone. I jokingly call them âBaby Aeolusâ.
Cheers!
Money shot!
Oof, so my right driver decided it can live no longer after only 1.5 months. Itâs been having some issues every now and then throughout November, but now it no longer plays at the same volume as the left - if it wants to play music at all.
Thankfully Amazon has the extended holiday return available, so Iâm going to request a replacement. If the driver doesmât completely kill itself before next week, Iâd like to do a side by side comparison of my Yaxi/Kramer-ed unit with the replacement as well as the Beige LE Iâll get on Monday.
Farewell buddy, you were amazing despite being so flawed
so, has anyone done the Grado pad mod to the PPâs?
I believe the porta pros driver housing is too small. I tried to put some of my various Grado pads on mine and none of them fit.
Did you mod the cable on this one? Iâve got orange Yaxis on mine too and I love them.
