Oh man! How do you like the Shozys?!?! Mine are supposed to come in this week.
They are my second favorite iem right now. Only behind the lz a6, but not by alot.
I am more active on head-fi: https://www.head-fi.org/members/rikudougoku.514119/
Also done a review on the 1.1 there you can go check it out.
Yep, Iāve read many of your posts, including that review.
Iām currently testing these, Iām really liking them so far, but have more work to do before my final opinion. I can say for sure that they are soft and comfortable, and I donāt dislike the sound on any iem Iāve tried so far. Does stuff with the staging that Iāve not studied enough yet lol.
Wow. That looks really interestingā¦
I currently use the medium size Dakoni Bulletz. Iām wanting to try out silicone and Iām looking at Spinfit CP100 line (Unless you guys recommend a different style). What size should I get? Would I still be a medium or should I go for the large instead? Also, does anybody happen to know what size fits the nozzle of the Shozy 1.1? I canāt find any info anywhere that tells whether they are a 4mm or 4.5mm diameter. I would be buying these new tips to use on them as well as possibly my BL-03.
@Mr_Makua If you have a measuring tape you can measure the nozzle across in centimeters and then convert that to millimeters.
I have had no problem getting 4 and 4.5mm tip openings onto the BL-03. They stretch out a little bit. The BL-03 are about 5mm in diameter for their nozzle.
Hopefully some of this helps.
I would also look at the cp145, seems to have a little larger 4.5mm opening compared to the 4mm 100.
Also on Amazon.com if you look closely, they give detailed measurements of all the dimensions of their products. You can use a measuring tape and compare to a tip you already have.
I really like these tips, I think they are different enough to have in your arsenal.
Ok, we can talk about tips. Just the tips!!
,ā¦
@Davidibiza got them today itself. Tennmak. Tried them. Theyāre smooth, i donāt get itchy ears with them compared to silicone tips, but they get uncomfortable after a while. I havenāt experimented with the other tips yet, but as of now, I have tried the medium sized. I like them, but would i recommend them? I donāt know yet. Stay tuned in the next episode of dragon ball z cue theme song
Thanks, Iām not a fan of foam eartips anywayā¦
Just tried the large ones. Big difference so far. What do you prefer as eartips then?
Silicone, for most of my iems I use Symbio or Spinfit.
These tips seem to have fixed all the shouty-ness of the Shuoer Tape. Also they are rather comfortable.
I wonder if I should just post a picture of my ears so you can try to see what tips might work on soon coming iems
Thatās not really going to help much. You just have to try different tips and sizes and start to get a feel for the size and shape of your ear.
Recently the best tips I have tried are the Final Audio E. Fit almost any IEMs I have and are the most comfortable I have tried so far.
Spinfit are also good.
Final type e are amazing, but they will add more bass so if you already have a bassy set this will only make it more bassy
Azla sedna
Spinfits
Acoustune
Are some other good tips
I have a patented process to help people test their ears, it requires you to have a friend lick their finger then stick it in your ear⦠
#corona
Interesting thoughts.
Personally I find them to do something cool with the bass. They somehow add a tiny bit more bass, yet incredibly tighten it up at the same time. I have never had that happen with any tips before. Using them on my MH755 and honestly they improve the sound altogether.
