i’ll probably go with those on some tin T2 to make them a little more fun (but i do like analytical so maybe something else since i like things sounding clear and netflix not sounding horrible)
Definitely like my Final E Series tips. They are my favorite so far. They seal nice, look nice, and feel like they will last for a long time. I got them so I could move away from foams and I haven’t missed them at all. Haven’t tried a lot of the others mentioned in this thread but I can vouch for these.
yup, the added bass also get tighter so that is a very unique effect of the Type E tips that I havent experienced with other tips.
You made me do it, lol. First impressions are good, gotta run all my iems with them for a bit to see what I think for sure.
So final audio e tips are stellar and up there with spiral dots as far as favorites go. The horn ones are good too, but more for a different sound with good comfort. I think it goes spiral dots, FA e tips, and then the horns. The bass is indeed tighter and more prolific and blows away the knock off sony hybrid tips I tried before. Very good sounding imo. For overkill pair with OH10
and for delightful bass pair with the Blon 03. No complaints really.
good to see you like them
Accoustune AET07 is my favorite tips, very comfortable and isolate well. The Stock tips on the MH755 is fairly comfortable as well and strangely well isolating.
Got these coming in a few days and will post some impressions since they appear to try and remove reflections while also being foam. My thought is it wont reduce treble overall, but maybe remove peaks and smooth treble like say a spiral dot would.
hopefully that’s the case!
The spiral groove tips are good, I feel they dont change the sound much and they are one of the more comfortable foams I’ve tried. IEMs retained clarity and worked well. No complaints.
Also got some more of the epro tips cus they are so damn good. I think ppl are sleeping on them…
One I got $100 bucks to deliver a bunch of liquor up to a penthouse. This was back in the 80s when $100 dollars was a decent chunk of change.
Yea, corn pop was a bad dude who ran with a lot of bad boys… Lmao that’s random man.
aren’t we talking about tips?
Touche, lmao I am somehow reminded of the scene from reservoir dogs…smh
Anyone rate JVC Spiral Dots?
They are great, I want to try the spiral dots ++ but that stuff is 50$ per size and I need 2 sizes so 100$ for tips is excessive for me in my mind. As a tip get something like a final audio e1000 and see what size tips fit you from their 5 sizes and then use that as a reference to see what sizes to buy. My list is spiral dots as default, then e type tips, then epro horn tips. The epro are so cool and odd that they can’t be 1 or 2.
Mate that’s crazy
in the UK I can get a 6 pack for £11.25 delivered free but it’ll take circa 1+ month for delivery…gonna order some any way ![]()
Found a better supplier $18 USD free post they should be here at the end of the month
I’m looking to try Spinfits for the first time. Always wanted to try them but never got round to it. Is there any difference between the CP100 and the CP145? The CP145 seems to be the most popular/recommended so I’m leaning towards those.
The CP145 has a longer stem than the CP100. So you get a better seal with it, especially on short nozzle iems like the blon 03.
Thanks, I’ve actually just ordered the BL-03 and I’m trying to make sure I have a selection of different tips so that I’m able to get a good fit haha. Do you use the CP145 with the BL-03?
