I use jvc spiral dots with them, as I need a big tip to fit with the 03 and found the bass to be too loose with narrow bore tips. But the CP145 is used for a lot of other stuff I have (although not as much as before I got the Final Type E tips, they are amazing)
I also have the JVC Spiral Dots so will give them a try with the BL-03 too once it arrives. Thanks for the help, Iāll go and order some CP145 to add to my tip collection. I also have some of the Final Type E tips and agree they are fantastic!
Try the epro tips too if you get a chance, they work great on the blon as you can push them down to the body of the IEM. Also cp360 fit well, they just dont sound very good imo as the treble becomes way to peaky with those from what I can tell.
If you want a deeper fit on the 03ās then I used to use a section of old tip bore (the orange bit) to push the tips further forwardā¦here on my old pair
The best tips for the Blon BL-03 are the Final Audio E Series tips, IMO. It not only improves the sound, but is extremely comfortable.
Thanks all for the suggestions. Iāll order the CP145s and see how it goes. Iāll try those, the spiral dots, and the final e type tips and fingers crossed I get something I like haha!
@Mufflertape Iāve never heard of the eproās they look pretty interesting, another tip to try out! Iām not a huge fan of peaky or harsh treble (a bit treble sensitive) so Iāll probably avoid the CP360 for now.
@Ohmboy Iām pretty sure I saw this post on the BL-03 thread haha. Certainly looks like a neat solution, will need to give it a go if Iām struggling to get a good fit. Thanks.
I agree with others on the Spirals and the final e tips first, then if you want it to still sound good, just a little different check out the horns then. No reason to spend the money right away but keep them in your back pocket as something to try. im still contemplating dropping WAY to much $$$$ on the new Spiral Dot ++ tips just because I know the spirals fit so well for me. smh, Will prob do it if I can here in a few weeks
Thats about what I paid as well, good job on that.
Yea they were worth the wait for me. They do great things for treble and comfort for me. If you look up the ++ version it came out last year and it is like the equivalent of getting ZMF pads or greater. It would be an easy pill to swallow if I only had 1 size for my ear canals, but I have 2. So I get more, but man do I have to pay to get it LOL.
Should be sweet with the Androās then ![]()
Azla sedna are a great alternative for the spiral dots
Got the symbio W and F tips in today. The W are really cool and seem well made and all, but like most silicon tips, they donāt seal in my right ear at all really. I was hoping these wound be The solution to my problem with silicon tips not fitting, but sadly they are not. The only silicon tips I found that seal with any semblance of reliability are misodiko s350 tips. These are great but they are a rather small boar (3.5mm) and tend to change the sound quite a bit (more sub bass and less upper mids) so I can only use them on certain IEMs.
Thankfully the F tips are great. They seem to be a perfect cross between the the great grippy material of the dekoni tips, the amazing anti itch material of the misodiko M430S, and the slow rebound memory foam of the complys. This means they stay in my ears really well (like the dekoni tips), donāt itch (like the misodiko tips), and do the comply expand in your ear thing which makes for a good seal (litteraly the only thing I liked about comply). If I donāt find any problems with using these for longer periods of time then these might just be my new go to tips. Also they donāt seem to sound any different that any other foam tips Iāve tried.
GOOD NEWS!!! They are 50% off right now
https://symbioeartips.com/termek/symbio-f-3pairs/
Very cool! I didnt know symbio made full foams. Must be a new product. Thanks for the heads up
Yepp I use a container now after the video Josh did, I love keeping them organized.
Does anyone know if itās possible to get custom tips in EU?
Custom tips?..CIEMās then yes depending on the OG supplier.
Iām not sure about EU availability, but these are the only custom TIP option I know of.
