Enjoy. Wish I had gotten BGVP eartips earlier, would have saved me hundreds of dollars.
Have you tried CP360?
Itās essentially a wide bore CP100. Similar to W01
No, Iāve never! I kinda stopped getting more tips as I found BVGP and I like their price ![]()
I bought them so I can try it on different iems. That makes me think I donāt even know if they have been shipped yetā¦
Those are TWS tips though.
Soā¦
10char
means they got a shorter nozzle than usually. So its something to keep in mind.
The E01 worked well on the Timeless though I prefer Sedna clear on the Timeless. Atm I am using WO1 on the Airship
They are nice. Weād to be on Amazon
I have used the CP360, before I got into IEMs. They are a TWS tip, which is very short for most IEMs, but I do have a M/S set from an old cheap TWS.
I liked the material, but wanted a deeper fit into my ears.
Check theese out super wide bore double Flange and soft
C$ 1.50 5%OFF | Two Layer Silicone Ear Pads In-Ear Earphone Earbuds Inner-diameter 5mm Original Covers Eartips Headphone Earcovers 6pcs/3pairs
Not gonna lie, but those look like the tips you get with Meze iems. The double flange ones are not bad imo.
They are surprisingly comfortable more so than the AZLA Crystal I was using puts letās pressure on my wierd ears
Iām also looking for something comfortable. howās the isolation, bass and overall sound quality of these??
Isolation is outstanding bass is great and highs because of the wide bore is fantastic same as stage. The EJ07M needs a longer tip tho because of the short stem so I tried them on the Globeās and love them
BGVP W01 arrived today and I must say I really like them with my Kinda Lavas.
I thought the bass would be less compared to CP100+ because of the wide bore, but I donāt hear much of a difference⦠Did no A/B testing yet though.
Treble and stage is fantastic
Seal is VERY good, can compete with xelastecs while being much cheaper with longer shelf life.
So far 100% recommended!
Got the AZLA SendaEarfit long stems in black and softer clear version in yesterday and itās perfect for the metal shell Lava. I found the stem really short and was hoping for a eartips to help a bit here and they are for me perfect.
Not quite the stickiness of the crystals but because of the added length the Bass is where I wanted it to be and I found the highs not have the correct amount of energy I like. Best tip so far for me was the Black long version.
Speaking about tips, Moondrop could make a version of the Spring tips but this time with longer stems and better seal for users since not all of the people who tried the original one fit them well, for it seems the M-sized tips are S-to some, and I am one of the few folks with those sizes just fit me perfectly.
(Itās a shame though, they make good shit yet due to their continuous QC issues that I had with their IEMs, the magic from them is going away. Freaking customer support is not that good from Moondrop.)
Agreed 100% and unfortunately for me I find the large too small and the XL too large with the soft flanges doesnāt work well. MD should have stuck with 13.3mm for the large. But I am happy they work for you and my daughter as well. Cheers J.
If you look at the outer diameter of the spring tips, youāll see that the M size is equivalent to the spinfitās S size.
I am one of the numerous users that has to use L size to get a seal. The M size could work (as CP145 work on me with S size) if they had a longer stem; sadly they donātā¦
These Moondrop tips are quite comfortable, and they tend to tame the bass, so they can be useful. but yeah, itās hard to get the good size with them.
