Agreed and have the swivel end like a spin fit theese really should get more notice
Fuck it, I am going to try the SpinFit W1s since those are have been in my eyes for a while now. Also I have the Heydays and so far it has been great even with the stock tips and stock cable, but a little bit of tip rolling and experimenting with other tips wouldnāt hurt so bad. Also when it come to its cable? I prefer it for inside use, might as well get an another to use when I am like out or something.
So far I am really happy with these Tri Clarion Tips I ordered from aliexpress.
They did look way too small at first sight but they fit really good in my usual size.
The more narrow tip of the tip (
) helps for a deeper fit and they create a nice sucking effect which helps to keep them secure.
The bore is very wide so the sound feels clear and open and I did not really notice a decrease in bass compared to alzla xelastecs
Still in the testing phase but so far so good
The deep fit makes them a perfect match for the short nozzle of EJ07m ![]()
Here are the physics behind them and I must say when I used xelastecs directly afterwards they sounded not as clear but I need more comparisons
They are good tips indeed! ![]()
I donāt use them anymore on my Heyday since I still prefer the Final E tips there but I use them on my TWS buds where they definitely help with comfort and keeping the seal while moving about
SpinFit W1s, they are actually pretty great to have though it took a bit to get used to it when wearing it in my ears especially out of the box. Surprisingly works well with my Heydays, though I think there might be other tips that are much more compatible with my Heydays.
I have been going with Dunu S&S for three days now. What I want to say) now put Spiral Dot 10 to listen. These spirals give out such a frank turbidity in sound on the bottoms ⦠Male vocals on the S&S are also better due to the extra weight and greater concentration, the female one has more presence
At the far and lower highs, the S&S has more intelligibility, which is actually a matter of taste and on some tracks you want more control, but somewhere you want a blur
If you want to listen to a stage, then itās more likely to contact Azla Sednaearfit Long Short, in the same place the upper frequencies will be better compared to spirals, but this is of course pampering, if you really want a stage, then this is for open full-size headphones
If you have small ears or need tips to reach deep insertion and forgot about iems, you donāt even need to adjust because they are a little sticky, I definitely recommend. I canāt vouch for everyone else) If it bothers you that the nozzle diameter is only 3.77 mm, then this is not a problem, the rubber bands stretch quite well (lol, ironic
Finally got around to trying The TRN T Tips after seeing them mentioned a few times by @domq422 and @GooberBM and theyāre fantastic, especially at the price. I think someone described them as neutral and thatās the exact description Iād give of them. So far the only IEMās Iāve tried them on that I didnāt like was my S12s and that was solely down to fit on that particular short nozzle.
Iād describe the material as grippy but not to the point where Iād call it sticky like the Spinfit W1s. Theyāre definitely becoming one of my default tips.
Iām happy the Rec worked out for you, brother ![]()
I have to order some more, all 3 of my pairs are currently living on 3 IEMs and that doesnāt happen often. I should of mentioned that for me personally, they donāt particularly work on shorter nozzles.
after trying them on a few sets, i went and bought a few more packs since lucklz has them on sale at $5 a pack right now
Another shout-out to @domq422 and @GooberBM for TRN-T tips! Never had such a perfect fit and seal while being deep down the ear with MEST up until this point. I guess it is what W1s were supposed to be for me.
The texture seems perfect, not as much of a dust collector as xelastecs, but still gripping walls of the the canal making the seal stellar.
They sound the most bassy out of my all tip collection, even borderline muddy on some tracks (like the treble sparkliness went back on Replica of The XX for example very evidently). It is contrary a bit to what was said on them previously, so I guess I may have never had a proper seal throughout one year with my most favourite IEM ![]()
All in all fantastic value for money!
Outside of AE, they are tough to find.
Anybody in here have suggestions on companies that do or can make custom silicone tips for any iem?
I only know of this.
But they donāt have everything.
Yeah I already know of them too, also Custom Arts in Poland who make tips that just involve the nozzles.
I had my custom tips made by Custom Art and even though they look quite funky, they provide massive improvement to the sound quality and comfort.
My ear canals are problematic and finding a pair of tips, which would fit them well enough, was always a challenge.
Thatās why I opted for going custom. And why I tend to pick up earbuds more and more often.
Craft Ears Aurum + Custom Art black metallic custom silicone tips
Nice man, Iām looking to probably going with them in the future unless I can find a company closer (preferably in the states) that can do the exact same tip work that donāt need the iem sent in to make them if they donāt have them.
Hello guys, my Final Audio Type E (S) tips are on the way. With all the praise the Deep Radius has got in this forum, Imma also order it but Iām confused what size I should go for. Type E Small size is 11.1mm in outer diameter while Deep Mount Small size is 11.5mm. Is the 0.4mm increase negligible, or should I go with the Deep Mount XS size (10mm)?
Since deep mount is not an even size the 11.5 should be just the maximum at one point in the umbrella portion. Your prob. Better trying that unless you want an extra deep fit to get the same seal with the smaller size. It may come down to what iem your using and how deep a fit it is designed for to properly match. Also you can get multi sized packs and go from there too.
@JAnonymous5150 im caving in and buying some of your TS-400 foam tips. If these are no good Iām gonna hold you personally responsible ![]()
Also grabbing some Whizzer SS20s because I like spending too much money and stupid shit lol. But at least I didnāt grab another cable I donāt need!
If theyāre not good, Iāll buy them from you. So now you have a money back guarantee. Doesnāt get any better than that. ,![]()
