I got S and M. You sure that works for you?
When it comes to tips Sonyâs EP-EX10A donât get enough propsâŚsimilar profile to Final E tips but theyâre softer and donât reduce the sound stage as muchâŚthey also deliver a more neutral and open sound signature ![]()
Those whizzer tips are really nice. I think youâll enjoy them, very similar to the Cap tips but with a thicker flange!
Are you able to get them in the uk at all? Been wanting to try some other tips
Hell yeah, I use all the sizes in various applications. Just let me know when your ready to sell.
I got my sets from Amazon UK but they do go in and out of stock so you have to patient and keep checking ![]()
My preferred tip.
I just got my whizzedrs last week and already ordered another set. Also ordered the âsoundstage setâ will see how those are as well. Super comfy and balanced
Thanks, Iâll keep an eye out for some, hopefully theyâll come back into stock soon
Iâm still waiting on my TS-400. They have been stateside and out of customs for a week but still MIA ![]()
You and me both. Iâm starting to expect my NEXT AliE order to come in before they do ![]()
Iâve picked up some tri clarion wide bores, some adv fedelity u oval tips and I really like both. The adv tips are short and on the smaller side. The tri tips(hehe) are up there with spiral dots and are prob. more comfortable.
These came a couple of weeks ago and are everything I hoped they would be soundwise. I get the awesome bass and isolation that comes with foams and but the stage and treble is unaffected. The only our is I wish they mad a size smaller than the smalls cause my IEMs have long nozzles and I have small ears ![]()
Iâm still waiting on customs. SoâŚboooooooooooooo
What about their build quality and longevity?
Do they feel like breaking apart after 2 weeks or so?
For the foam tips? Quality is top notch. Iâve only had them for few days so canât speak to longevity but maybe @JAnonymous5150 can chime in
They last as long or longer than any foam timp I have ever used. They last me significantly linger than some Comply models. Basically, I can vouch for them beining a quality tip.
You know Iâm gonna say all this then the shop is gonnna go on strike and put out a shitty batchâŚ![]()
Just got some ET100 tips from @ctjacks336 (thanks man!) and with the EA500 the seal is top notch. I feel vocals are brought very close and are smooth. Very early impressions are that I like this shape for my ear canals!
Itâs definitely a unique shape,but works
