that’s it … you pretty much sold S12 to me
(that impression came from the fact that I’ve heard they “are” wide … but need amp otherwise will sound narrow…!)
This means system is case insensetive. Now it makes me wonder it treats password Abc and abc the same
You might be able to do it by first changing it to something else (temporarily) and then make it all caps?
It’s probably just the titles that work this way.
How is the channel balance guys?
I have no way to measure it, but it sounds fine to my ears.
Don’t have a measuring rig, but imperceivable to my ears
All good
How is the resolution? Does it pick up everything like timeless does?
To my ears, is more detailed, without being as harsh.
Compared to timeless? What are other differences?
In case people missed out on the early bird sales, @shuoer is running another promo! Go go go
thanks for sharing, how much was early bird price?
It was 129.99 USD for just the S12
Easy and decent sub bass treatment for the S12 with parametric eq.
EQ applied:
Low Shelf @40Hz
Gain 3dB
Q 1
Sound demo with disclaimer: As always in reality it sounds different, this only for rough comparison.
Cool! Have you tried putting a tuning tape on the vent? Might be worth a try. EQ is handy but a pain if you have to swap around sources and IEMs…
thanks for the reminder…trying it now.
Fully taping helps a bit you’ll gain around 2dB more sub bass at normal listening level.
The S12 has 2 vents
which I taped masterfully for science
I recorded the same track at same volume 1x taped and 1x untaped. Then I checked the audio spectrum in iZotope RX7. There I looked at the dB amplitude of the first strong bass impulse at around 40Hz.
Untaped (amplitude = -24.7 dB):
Taped (amplitude = -22.4 dB):
So in this scenario I gained -22.4 dB - -24.7 dB = 2.3 dB
and finally the sound demo:
You da man! thanks for all your contributions
