Thank you
Iām gonna look it over and see how it works
So azla tips work great for me, improved the sound more than the foam tips, agree they are a little stiff but a good seal. Stage and seperation is awesome. And mid vocals are lush and right there haha
Awesome. I think Iām done with foam. They just canāt compete with silicone for serious listening, although their comfort is great.
The Azla tips are the best tips Iāve found that increase the perceived size of the sound stage, but because of the dense silicone, I find getting a perfect seal in my ears with them just doesnāt work that well. I prefer soft silicone for a really strong seal. I wish I could find some wide bore tips with the soft silicone like the Spinfits. That would be the ultimate tip IMO.
Yea that would be really nice. Happy with the azla though, just a little weird on the left still but not as bad as other silicone tips. And sound is just great
I found them. I didnāt know Azla had the different types of wide bore tips.
Oh perfect hahaā¦although i do like the sound of their regular tips and light tips might take away too much hmmm
I think that just lets you know what nozzle sizes fit with the different hardnessās of tips?..different hardness will also effect the sound too so itās a bit of a
On drop for $260 and ships 9/10
Id pay 40 more and get them right away
- Nothing can be matched with this monster in this price.
- Small unit though it has 1dd and 6ba.
- Bass and treble is a bit emphasized.
- Nothing to say⦠BUY IT.
$100.00 cheaperā¦
https://forum.hifiguides.com/t/isn-audio-h40-3ba-1-dynamic-driver-hybrid/14627/14?u=papaemeritus
I love both.
You can post in here.
Thanks, gotta check!
Anyone know whatās the dynamic driver diameter of tea?
no info about it, but i think est around 9-10mm. but what matters is they sounds great, esp on subbass.
first time listened them on a desktop amp - damn, its even better. Makes me wonder why buy full size headphones at all
simply stunning
This concept always amuses me, like spending $500+ on a premium power cable for an amp, then looking at the houseās wiring. Just like those that spend thousands of dollars on speaker cables, but you look at the internal wiring, and it looks just like those internal HP wires.
Snake Oil.
Unfortunately, I canāt take my own advise and ordered thisā¦
https://www.fiio.com/productinfo/422239.html
I really wanted those swappable plugs. ![]()
Ok then calm down and listen.
Couldnāt you just get the dunu dk2001 and get their replaceable cable. Then you get the iem and the cable for 300 usd.
Which is like paying 100 usd for the iem (from the perspective of the fiio cable) or it would be much cheaper if you could sell the dk2001 without the stock cable.
What do you think about my master strategy?
