This is the official thread for the MiM Dark Magician
- Type: In Ear
- Amp needed: No but Better With
- Driver Type: Single DD
Sorry the product link isnât working something to do with the formatting
trying to get it sorted
EditâŠFixed
At least one user was requesting some photos of them and the accessories, so here are some I took during the best period of lighting today, Iâm afraid thatâs all I can say about these I am not using a very good camera and I did not take any serious time to clear some space or stage anything.
(Iâm making a waving âcameoâ in one of these!)
Mine are the darker looking variant as opposed to silver. I know theyâd pair beautifully with one of XINHSâ graphene cables such as @nymz and others have so beautifully displayed.
I mostly kept these photos to stock accessories, but one is just how Iâve been wearing them (Whirlwind tips, slender cable from Aladdin)
On a tip-rolling note â I have found that the wider the bore the better for spacial feeling and for the bass. At least in my ears, narrower tips take some definition away from male vocalists and kind of ruin what is otherwise some of the most sublime bass Iâve heard from an IEM.
Is MiM an exclusive brand from this Ethan guy? Itâd be cool if it was easier to get this one.
I think so? Itâs DIY, right @rattlingblanketwoman?
Mine was lightly used, but originally from the maker himself. Seems he is the only outlet (Carousell link in first post)
Before I am known as the guy who picked Oxygen over the best IEM in the world, I will say it came down to my preferences and my library more than any significant difference in the sets. If Oxygen is already on the low side of your bass preference, DM takes it down a bit. For me, I would rather sacrifice a bit of DMâs bass detail for Oxygenâs level as it works better in my library. For those who find Oxygenâs pinna gain fatiguing after a bit and limiting your volume, DM solves that. If you prefer more of that upper mid emphasis/low treble on vocals and instruments to add energy and engagement, then Oxygen.
As I said, most of it is just preferences. I prefer EJ07M over EJ07 for the same reasons. For my library, I will take a bit of extra bass and treble even if those sacrifice mids perfection. For me, I would own the DM and then EQ it halfway to Oxygen which isnât a bad idea. Or just keep the Oxygen and my EJ07M.
Yeah Dark Magician is pretty good imo. Itâs neutral with a bit of a bass boost so itâs not flat, and a mild 6k dip to prevent fatigue. Bass is nice and punchy. Timbre is excellent. Staging/imaging falls into the category of âits fineâ, as expected from a single-DD.
Itâs great for people who are sick of Harman IEMs with overpowering sub-bass, scooped lower mids, and shouty upper mids/lower treble. Everything sounds balanced and refined across the board.
I think itâs worth checking out if you like the tuning, although itâs going to take some extra steps to acquire one. Buying from Ethan was super smooth, just PM him on Carousell. After shipping/currency conversion/fees etc, expect to pay ~600$ for one new.
I saw a graph of how taping the main vent could increase sub-bass substantially while not really touching the other areas of the FR.
The response to my ears however:
So to my ears, not a recommended mod. Even as someone who adores elevated sub-bass, I have not been missing it from the FR of the DM. The sub-bass/mid-bass levels are already very well tuned. What I can feel and hear seems right.
I am having a few more fit issues than at first. The shell itself does nothing to steady/secure compared to a standard UIEM design. This is of course super dependent on anatomy, Iâm just talking about mine.
This led to a bit of a compromise where I wanted to use the widest bore tips I had, but needed them to extend quite deep as the contact points of the tips is the only security of fit/seal for me with this shape.
I also find the space around the shell and the lack of contact of shell to canal means isolation is not as full as with standard shapes like the Aladdin or Oracle. Almost all the listening so far had been at my desk at home. But in normal day to day life, 3/4 of my listening at least involves background noise. Without great isolation, what may be perfect bass at my desk can sound very quiet and less tangible while driving/ with running water. My current compromise that Iâll try out on the move is that I found some longer profile double flange tips (usual dome shapes) that is giving a very secure hold and seal, and I will have to see how well it has boosted isolation. I say compromise because it does have regular (narrower) bore than the tips that were providing the best acoustics for me.
Memory-foam washers (foam tips cut down to just a rim that simply seal around an unadulterated nozzle) provided great sound and seal, but I donât consider something that needs squashing and holding in place every re-insertion to be EDC material.
Either way because the fit is so dependent on canal and not held/guided in place by my outer ear, it is a little more fidgety every time I first put them on, reminds me of Etymotic ER2XR (obviously not the depth!) / Final E4000 / to some extent NF Audio NM2+ fit where Iâm holding my ear stretched and really choosing the right angle from the infinite available approaches. The Aladdins and Oracles are tied for much higher convenience over this fit.
Edit: Iâm hating that the best fit I can get is still not that secure of a fit. Iâm having flashbacks to the FDX1 which I was a big fan of⊠except for their fit.
(SOLD)
Call me crazy, but I have to deliberate quickly especially with pricier IEMs. Fit is the dealbreaker on these for me, mine are available in the buy/sell thread. If I had infinite money to keep these as desktop critical listeners, oh I would.
@nymz, this is your chance
@nymz, are you sleeping?
Shame about the fit, I had the same problem with the Dunu Zen; loved the sound, couldnât deal with the discomfort.
Sorry I was working. Im in EU, no chance for me (vat).
Same here, EU as well. Would consider it, but due to VAT Iâll have to pass.
I literally just ordered these and saw this thread. Probably wonât be receiving them for a month or so, but from the data Iâve read and seen about these, they seem possibly quite perfect for my library and preferences. Iâll come back in a month or so and talk about my experience.
What tips did any buyers of these get with them? I canât seem to find that info and the seller said âwe arenât sure yet, but good tipsâ in an email, lol.
AET07 / sometimes made by KBEar as KBEar07
Ahh, thank you! You are a great resource there. Every video or photo or comment I found on these just showed them without tips, or showed that a customer had put their own tip on. I wanted to know if I should look at buying my own tips before this arrives.
Super excited. Iâve been researching my ideal IEM for about 2 years, and was originally looking at the A/U12T. I couldnt quite throw down the $2k right now, but $600 I can do. I hope the bass shelf the DM has is as good for me as I expect. If not, welp, Iâll save for a bit more and get the U12.
