That would work just fine as long as your agrons are balanced. Although perhaps look into some other amps as well besides thx
Maybe you have some sugestions
I think finding a used monolith liquid platinum or used cayin iha6 would be really nice imo
I think those are out of my bugdet unfotunetlly.But thanks for suggestion anyway
Gotcha, then I would def consider the asgard 3 as soren mentions
Thanks a lot
Just got a balanced pair (got the balanced option just in case), would an Audio GD NFB-11 be enough to drive these? Or would you recommend something else ($400 and down would be my budget)?
That should have plenty of power on tap, do you have it already or are you in the market for a dac/amp?
Currently have it, just wonder if they pair well, thereâs plenty of volume, just wonder if theyâre being driven decently
Yeah I would say you are most likely just fine with it
Sweet, thanks for the help. Would you recommend any other headphone to be a companion to the Argons?
Also, off topic, any music/movies I should check out relative to the Argons?
Would you be looking for something more neutral then is my guess?
I mean mostly anything with bass is typically fun on the argons, and it actually handles poorly recorded music decently well. I personally donât watch movies/tv so I canât say anything there lol
Yeah I guess something neutral, since Argons are tuned towards fun sounding. With the exception of the HD 600, just cause the comfort and narrowness just donât vibe with me.
Mmm thatâs fair, I guess my intention with that question was if anyone had some song or album that they really enjoyed personally while auditioning the Argons, but there is a place to post those sort of questions I suppose lol
Well itâs been exactly 12 weeks since my order and Ryan estimates heâs about a week behind so I guess mine should be shipping soon
I am a bit nervous about his most recent news update indicating supply issues during COVID-19. He doesnât specify if the supply issues impact existing or only new orders
I went with the Sundaras as a more neutral compliment. Both are around the same price depending on what mods on the argon weâre talking, and give a completely different experience. The imaging is much, much better and has a much more narrow sound stage. Both require about the same amount of power too.
Sounds good, hopefully I can try a pair at some point this year. Thanks for the recommendation!
I am nearing the shipping date of my Argons, so itâs time to gear up! Can anyone say how much power they REALLY need? Z seemed to be satisfied with them on the Rebel, which is 1W at 32 Ohm, the Arcam rhead is 1.1W so should it be enough to drive them? That amp looks very appealing to me.
What do you have right now?
Literally nothing. Iâve sold all my stuff (Audio-gd amp and MrSpeakers Aeons) when I ordered the Argon. I am doing audio detox since then, I survive with a VE Monk+
Gotcha, so what are the prices you can get for the arcam or an asgard 3?
