New 350$ Planars -Thieaudio Phantom
That is correct, as shown in the photos above
How do you know what end is which or the driver side?
On all Phantoms I’ve seen, plus on my own, The left terminal always gets wired to the casing on the 2.5mm jack. That means that it must be the negative.
Spent longer than that. Used them a fair bit out of town also but wanted to wait to film a review till I could confirm my theories in the quiet of my home.
No I just genuinely find them to be unacceptable for their price. No excuse for it in 2019.
Oh. I saw your messages in Discord when you got them on Tuesday and on Wednesday you said that you were filming your review. Are your Phantoms from the first batch?
Yes those are first batch Phantoms.
Same as what Z had since his behind the scenes video.
Fair - Did you try them without the grills? I just took off the fabric they glued on like @ConnorG suggested and it does open them up a bit.
I did try them open and with a large variety of pads.
Also I want to note that in my distaste of these headphones or anything I may say about them I intend NO disrespect towards Connor, Z, or anyone else who does like them.
Of course, I hope nobody is actually offended. This stuff is far from a science.
Shit. You are completely right. I put them back to this. Thanks.
If anything, I respect you even more than before. No disrespect taken. You gave your honest impressions on these headphones. Audio is a funny niche, where subjectivity takes over peoples thoughts and emotions, getting the best of people. I appreciate your honesty.
Ok so the foam is out and the materials are pulled off - still a bit muffled to me. What else can I try?
I like the low end (could be because this is my first set of planars) but I’m not blown away.
My little dot 1 opens them up but then kills the bass.
It definitely want’s to perform - just feels like something small is holding it back…
Some people call it snake oil, but I let mine burn in for about 30 hours… I’m waiting on others to crucify me for recommending this :grimacing:
Burn in and change the pads
LOL! Will give it a week or so I guess.
What about the rectangular piece of foam under the pads?
I’ve two sets of the exact same pads… Thanks Linsoul!
They’re different, The hybrid one is the better one among the stock pads. Look inside the rim one has perforated leather.
Brainwaves xl are good too
