Tried my Samsung s10e, sony a45 and balanced out from topping dx7s, still muddy.
sony and samsung wouldnt have enough power to drive Phantoms properly. Topping have more than enough power though.
Word on the street is that they do change a bit with burn in
There are two reasons why it will not work. One is on the Phantome the fazor fits inside the wood casing, while on the M1060s it does not. The fazor on the M1060 is on the edge. Two is the distance between the holes for the screws are different. The distance on the Phantoms is about 6.6 cm, while the distance on the M1060s is about 7.2 cm.
I just posted photo of fazor that fits perfectly
Is that the Phantoms or M1060s?
thats Phantom with 3d printed M1060 fazor
Looking for some help from the more experienced modders (which is pretty much everyone compared to me). I’m loving the detail of this headphone but I’ve noticed for some songs with female vocalists, (Norman Fucking Rockwell - Lana Del Ray, Adele songs for example) it sounds like the lead vocal is being shouted at me from the top of my head.
What might account for this, and is there an adjustment I can make that can help?
Mods done:
Square foam from inside earpad removed
Grill fabric removed
Pad swap to ZMF Suede Oval
One small piece of circle foam removed removed and one left in and centered
Large 3mm foam covering outside of driver (doesn’t fit perfectly, covers about 90% of the circle)
Thanks in advance for any responses!
Try equalizer APO+Peace and load up this file: https://mega.nz/#!jwVEEIaB!OLMdI91BoXuCKhzxUE5H-mNbAme6trVIaZ8rwjVSOZ0
It’s not perfect or even objective, but it’s way better thank stock for my taste and the music I listen to.
THEY’RE HERE.
Here are my detailed first impressions after some listening, modding, and measuring.
Preface -
I took some rough measurements using this method - Easy (but rough) frequency response measurements!
I will be discussing measurements, but will not be posting any plots right now as they can be misleading. They don’t take into account the transfer function of the phone, and it’s a shitty microphone, so they’re not good absolute measurements, but good for direct mod comparisons. If I talk about comparisons of mods, it might be from the measurements, but if I talk about how they sound, that’s from listening, not measurements.
One more note is that I don’t have much listening time with these yet, so their sound may just take some getting used to.
I also used this online tool - Online Tone Generator - generate pure tones of any frequency
It really helps to highlight suppressions or enhancements through the frequency spectrum. Great for EQ’ing if you have good ears.
Last preface - I’ve been listening almost exclusively to my 6XX’s, so most listening impressions are relative to those.
Packaging -
Well, I only got one set of pads… Everything else was included.
First listening impressions -
I listened and took measurements with stock, microsuede XL, and brainwavs pleather oval angled pads, all with the headphones in stock form, with the grills off, and with all the foam removed + grills off.
To my ears the best setup was with everything off and the brainwavz angled ovals. I also think that the XL are a bit too big for these, I had the ovals lying around and they stretched over fine. Going to order the standard round ones and try those out.
Well, first impressions, to be honest, are that @DMS was right…
There is a very clear dip from 1.5 kHz to ~2.3 kHz that you can hear very clearly with that tool linked above. His measurements show an even deeper dip from ~3 kHz to ~6 kHz, but I didn’t hear or measure any such dip on my set. There is rolloff though from ~2.3 kHz - 10 kHz.
I definitely perceived a lack of detail, probably due to that dip and rolloff. The angled pleathers seemed to remove this dip the most, but not completely. I will say, for what it’s worth, these measured astonishingly flat in my setup from ~50 Hz to 1 kHz, so that was neat. The bass sounded good to me from the small amount of listening I did.
I did find a random change that actually cleared everything up for me but I need to experiment with it more. I’d be interested if other people find the same thing.
I essentially made these semi-closed by covering up the backs with a thick cloth I had. It was a knee-sleeve actually, so dense, elastic cloth (was just lying on my floor, lol).
This took them from sounding sort of veiled and dull to more clear (less soundstage though). This was a measurable difference as well. It improved but the 1.5 kHz dip and the roll off compared with other mods.
If anyone can find a mod that removes that dip or really noticeably mitigates it, and also improves the roll off (using the slider tool linked above), then these will sound dramatically improved (to me at least
ANYWAY, they’re burning in now, so we’ll see after a few days of listening and tampering if they improve. I’ll post a more detailed review then. I’m thinking now that the mesh on the grills was an attempt to add some volume at frequencies…
TLDR - clear dip from 1.5-2.3 kHz, then roll off after 2.3 kHz makes them sound veiled/dull to my ears. I have hope after some initial experimenting. Going to try and find a mod-set that improves these things.
edit - listening with Topping D70 and THXAAA789 if people are wondering
Has anybody tried EQ’ing these?
Take the left over circle foam and place it on the inside upper part of the planar see if that helps…just a thought
2 posts up over yours mate ![]()
Lol! I read that post totally differently the first time around…
Yeah I’m getting that impression of veil. They are capable of soundstage and detail but it sounds like theres a band or orchestra playing in a large hall and theres a wall behind them and you are standing behind that wall. Leaving them to burn in overnight
EDIT: Originals were really not that good. Here’s the updated view:
This is what I’m using to validate the EQ:
Must give this app a try when I am back from travels.
Peace out boys and girls…
Enjoy RMAF!
Thanks for persevering with those oval Brainwavz! You just spared me from the stock pads because I gave up too early ![]()
The velour memory foam pads are way better than stock, even if the sound stayed the same.
EDIT: Also, just because it hasn’t been mentioned: with the EQ I’m using these are excellent for gaming!
Thanks flipflops for the preset EQ. I’m definitely going to give it a try as soon as my headphone arrive. USPS pickup my headphones up at LAX 6 days ago . I live 240 miles from L.A , they literally could of got here faster by mule train. Well time for a beer. USPS, I wish could hit them with a rolled up newspaper… Bad postal service , bad post service! ![]()
I can’t get over how talented some of you are. I have no idea what I’m doing, but copied the EQ settings posted in the thread and Lana Del Rey is no longer shouting at me.
The only issue for me is that I use Roon, and the EQ there is really intimidating. Not sure how to transfer over the settings from Peace to Roon.
Great progress though. Was getting a bit discouraged but the EQ settings really helped the issue I was having.
Thanks to everyone who continues to create improvements.
Okay. I did end up figuring out EQ in Roon. However, what sounded better to my ears was putting the square block of foam back in w/no EQ. I think that’s how I’ll leave it for a while.
