You guys!! ![]()
De nada amigo ![]()
Iād say of the sets Iāve heard: Olina and TRI Starsea would be the two sets you would want, at that under $150 range
Nah KAI is a sidegrade for sure. I A/B both of them and Zero definitely has more details and clarity due to its tuning. KAIās got more bass and more forward vocals and itās very good for loud volume listening since thereās no fatigue, but to me itās missing a lot of the frequency range (I wrote a review on the KAI here IEM discussion thread - #3522 by VIVIDICI_111). Zero overall is the better tuned IEM to me; gonna drop a full review on it sometime this week. IMO itās the best tuned IEM under $100.
Also the EJ07 sale is closed rip @nymz @pylaczynski ![]()
Youāre right about the 3-4k notch Zero has giving more detail, but for my ear that notch is TOO fatiguing.
Which is to say, weāre saying the exact same thing but you can handle that notch. I need it to be at least 2db lower, for me to stand that for a long time
Oh, that totally depends on the listening volume. If I crank it up more the Zero also gets fatiguing to me. The difference is that Iām using the Zero for work/background music so I just listen to it mid-volume which is why the 3-4K region doesnāt bother me. I use TEA for loud listening when I get home ![]()
I would have disagreed that Zeroās tuning is better, because for me itās not a great tuning if I have to turn down the volume to listen to it for a long period. But when you explain it that way, I get it.
#UseCaseMatters
My (terrible) anc BT sony at 2am after a 3hour review session sounds as good as my u12t for youtube goofing. Thereās so many variables in this hobby
Also loud to me is 80db+
I probably listen close to 90/100db oops ![]()
Really depends on genre as well. Zero does my POP/R&B//Alternative library well at higher-volumes, but no rock for sure.
I hear you. This whole thing got me curious and all KAI needs is +2.5 db with a Q of .75-1.00 at 6000-6500 hz and the details open up and you keep all the rest of the goodness.
Sound is a hell of a thing lol
Moondrop Blessing 2 and Blessing 2: Dusk - Shootout
Disclaimer (Blessing 2): This unit was sent to me by @Szymon to be graphed and for a quick spin. No incentives of any kind were given and the review you are about to read are my own thoughts and opinions. Thanks once again to Szymon for the opportunity and support.
Disclaimer (B2: Dusk): This unit was sent to me by @SenyorC to be graphed and for a quick spin. No incentives of any kind were given and the review you are about to read are my own thoughts and opinions. Thanks once again to SenyorC for the opportunity and support.
Driver Setup: 1DD+4BA
Price: $320
Comfort, fit and isolation: Good overall, but people with small ears be aware that the nozzle is very thick.
Source used: Topping E30 + L30 stack (both 3.5mm stock cable)
Tips used: BGVP A07
Test playlist with some of the songs used: Tidal
Took me a good while, but the day has finally come and I got the chance to try out two of the most talked and recommended sets around the $300 range. The Blessing 2 (B2) and the Blessing 2: Dusk (Dusk) have been acclaimed to be the technical set to beat at around the $300 range, so without further ado, letās dive into the sound.
Tonality
Hans Zimmer - Why So Serious? [3:25m]
While B2 did not impress me, just did the bare minimum for the league it plays for, the Dusk took the reins in that regard. Despite not being the best specimen, the sense of claustrophobia and extension were better noticed on Dusk due to its elevation and sub-bass over mid-bass type of tuning, while the B2 felt soft on the rumble and nothing to call home about, reminiscent of a BA bass.
Vulfpeck - Disco Ulysses (Instrumental)
On this track we are going to analyze Joe Dartās bass line, starting at 1:54m and the inclusion of the pianos and guitars around 2:24 and onwards. Just this sample gives us an idea of bass, mids, treble and some technicalities.
The first thing I usually notice is the latter and then my brain shifts into the tuning, so thatās where Iāll start. The technicalities on both units are all over the place. Detail, separation/layering and stereo imaging are all top of the line at this price point and I will talk about them shortly. What pumps up my spidey senses are the timbre and coherency.
The coherency on the Blessing 2 is pretty terrible, as you can easily distinguish between the parts of the frequency range, as if you could tell where the bass, mids and treble start/end. The timbre has the usual BA plasticity that gets more evident in the treble region due to its elevation.
These effects are less prominent on Dusk , due to the tuning adjustments - especially bass to mids, - but itās still present.
Now, focusing back on the tonality, the bass guitar position is shyer than it should be on the Dusk and less so on the B2. The mid-bass quality is pillowy on both sets and due to the Duskās tuck in to fit in a better sub-bass curve, the lower-mids took a hit. The lower-mids/mid-bass are the weakest point of both sets regarding tonality - again, it comes across more of a BA bass with not many dynamics and definition.
Despite Duskās mid-bass being cleaner due to the recession in comparison, for jazz songs like this one I would still take the Blessing 2 due to its warmer nature and thicker note weight. For those who prefer U-shaped IEMs or clinical mid-range, Dusk is the way.
Moving into the rest of the mid-range, this is where both sets shine tonaly wise, diverging only on the note-weight department, with B2 being thicker and warmer and the Dusk more neutral and transparent.
Both are clean and transparent, showing great sense of layering and separation when both Coryās and Theoās chime in at the same time as the pianos. This is one of the best mid-range replays, if not the best, you can get for this price range and rivaling the Tea lineup due to its resolving power.
Now, when analyzing the higher pitch notes and their harmonics, this is where it drops down a little for my own tastes. The upper-mids and treble are a little too energetic for my tastes and indisputably grainy. Curious enough, the Dusk feels less like to my ears, which shouldnāt be the case given the warmer glide of the Blessing 2.
As for the rest of the technicalities, those are also indisputably great.
Fleetwood Mac - Dreams
Iām gonna use this track to wrap-up my conclusions about the sound of the two sets. First weāre gonna look at the intro cymbal, followed by Steve Nickās vocals plus back vocals and all this while keeping an eye on treble levels and sparkles.
Right off the bat, the cymbal strike feels a hair too energetic from me on both sets on moderate volumes. As for the vocals, the mid-range advantage of the B2 with its added warmth replay better the vocals for my taste, but those who prefer the more neutral/clinical replays, will take the Dusk home.
As for the treble, well, as mentioned above thereās a couple dbs more than my liking so thereās sure enough, just wish it had a couple more DBs after 6k hz to back of the lower parts of this region, as it doesnāt match as much.
Verdict
Blessing 2 feels wonky in the lower mids and for that, I have to attribute the tonality factor to the Dusk. Iām usually against tucked in shelves but the added clarity and somewhat sounding more correct to my ears made my decision in favor of it. Other than that, the rest of the spectrum goes in almost hand to hand and I donāt feel it will be the deciding favor on someone torn apart between the two.
Now, the Beauty and the Beast story comes up: the technicalities. If the tonality looks good for your preferences and library and timbre, coherency and bass texture isnāt something you care for or can perceive, the rest of the technicalities will take you places.
For the price both sets have great stereoimaging, detail, separation and macro dynamics and in those regards on a single package, they are the pack leader at $330.
As for me personally, the timbre, bass texture and grainy treble are a turn-off, but I would be crazy to not give my recommendation on both if you are making an educated decision. Between the two, I do prefer the Dusk because of its overall tonality and the better grade goes along that. In fact, Iād go further and say I might prefer it on FR alone more than I do Variations, but the technicalities are no match.
Last three words of the review: stock cable sucks.
Moondrop Blessing 2 - Value Rating: 4.5/5. Personal ranking: B+.
Moondrop Blessing 2 Dusk - Value Rating: 5/5. Personal ranking: A-.
Thanks for reading!
Joe Dart! Yeah baby!
I feel the same way about these sets, very fair praise and criticism.
Honnestly, the teas showed me that there is room for noticeable improvements when you go past the 200$ barrier. The thing is though, Iām reluctant to go there because one set being way better doesnāt mean the other sets are on par: I know that the Tea are a special set, even for its price bracket.
Now that my/your teas are in hospital (I may try some depserate moves like open-heart surgery or 10 minutes in an oven, like graphics cards before declaring them dead), I am still reluctant to go there: I know I want to; I could even say I need to get there because the tea brought me a part of what I look for in music gear. But Iām too affraid of being upset after having spent this kind of money.
for everyday use and non audiophile people though I do agree: a good dongle and an approx $100 iem get you on a really good place, probably better than where you have ever been before; but for audiophiles like us, my guess is the sweet spot would be more in the $500 region.
Oh man, that review doesnāt help my case at the momentā¦
Itās not your cup of Tea, heheh
blessing 2 is not tea, and thatās why they could get me interested.
But Iām wary of Moondrop QC issues even more than I am with xennāsā¦
Iād love to see your take on the yanyin Cannon, as it seems to be the most serious contender for me. do you plan to review it, by any chance?
The ej07 is undoubtedly a better option than the ej07m at the moment, even if the latter is cheaper.
But of course. Itās still 600⬠and itās a risk.
Before spending that money on an iem I would try it first or at least have many guarantees of being able to return it.
There are reviewers who love the Ej07 but quite a few non reviewer consumers who donāt think itās decent but nothing more.
My thoughts exactly. Great tech, but treble region and timbre on the Dusk was a turn off for me as well. TEA squad all the way ![]()
@Roberto_Enther Ya for sure. Thanks for the heads up! But unfortunately there arenāt any places near me to try them out, but I do trust @nymz who is a fellow cookie addict ![]()
I recall you saying youāre located in Canada?
DM if youāre in the GTA. Iāve got a set of OG EJ07s that you can try. Unfortunately, Iād be reluctant to ship them out.
I asked to Tony but he has been MIA. I will let u know once I get it.
