I will be laying on my bed when listening to my headphone so i will go with 7ft length cable or should i go for the 10ft or is 10ft overkill? So Termination choose PRO?
If you are laying down 10ft might be helpful
Yes
If I have anymore questions in the future i will i be able to reach out to you?
Sure, just send me a pm or @me in this thread
Because i might move up to top tier headphones in the future
Do you have like a Facebook or Instagram? Maybe that’s a better option to reach out to you.
No, only here unfortunately lol. I do have a discord though
Okay, no problem, can i have a link to your page to click on?
If you check my profile on the forums it will have more info
Do i still need the 4.4mm to 4-Pin XLR Female Balanced Headphone Adapter for the Headphones?
So, this depends. If you get a balanced periapt cable yes, but then you would want to get two adapters, one being the 4.4mm and the other being the 1/4 inch. So with the PRO termination it will only work on the asgard 3, if you get the PRO XLR termination, it will work on the hiby balanced IF you get that xlr to 4.4mm AND a xlr to 1/4 inch adapter for the asgard 3
I would be using the Hiby R6 Pro to play the music and everything, so what setup do you suggest?
Would you be using it to power the headphones more or feed the amp more?
If you want the most flexibility you would get the periapt cable with the PRO XLR, and then get these 2 adapters for it (one is for 1/4 inch and the other is for 4.4mm balanced):
So getting the pro xlr termination and the adapters would allow you to get the most out of it imo as you can drive them on the r6 pro if you need to go portable, and then when you wanted to use them on the asgard you can swap on the 1/4 inch adapter. That way you can use more amps with it in the future @KT08
Which one would be best to get out the full potential of the headphones?
So do i buy both of those adapters that is listed above? And the periapt cable, for the Termination i choose the PROXLR option?
Yes, one for the 4.4mm balanced (in case you want to use the hiby as an amp if you want to go portable), and then the other one for the 1/4 inch (so you can plug it into the asgard 3). You would pick the PRO XLR option now
If you don’t mind, i am sorry to ask you about this, can you list everything, for the whole setup? Again Sorry for being a pain to you.
No problem
https://www.schiit.com/products/asgard (no module, finish of your choice, 115 v if you are in the us, us plug if you are in the us)
https://periaptcables.com/collections/frontpage/products/8-type-8-dual-3-5mm?variant=13627727937641 (with the PRO XLR termination)
https://www.amazon.com/NewFantasia-Balanced-headphone-Adapter-NW-WM1Z/dp/B07DD3X4KQ/ref=sr_1_9?tag=hififorums-20 (for using it with the hiby)
https://www.amazon.com/NewFantasia-Adapter-Balanced-Female-Headphone/dp/B07D7LG5BL/ref=sr_1_3?tag=hififorums-20 (for the asgard 3)
What will this be connected to? What length would be best for my set up on my Night Stand?
This would go from your r6 pro → to asgard 3 rca in. I would grab the 10ft if you are going to be using it from your night stand
