I have this one:
8 Core Silver Plated Wire Earphone Cable 2PIN/TFZ/MMCX/QDC Earbuds Cable For SE846 SE535 UE900S ED12 TRN V80 V20 V10|Earphone Accessories| - AliExpress.
Tbh the cable is a bit stiff compared to my Kbear or Yinyoo ones. But it looks great and feels sturdy
Oh and if you want pics, check out my Aladdin vs Oxygen post: IEM discussion thread - #2192 by ttorbic.
The latest release from Moondrop looks nice. Would have been better if these had replaceable plugs.
So I’ve been noticing this “Green” thing near the connector in the variations stock cable and it seems that I may need to change soon. It still sounds good, but better to change than be sorry later.
Any recommendations for a replacement cable or an upgrade cable for the variations? I don’t plan on spending toooo much on it, but I don’t mind spending like around $100 if need be.
I noticed one of my local audio stores are selling NiceHCK, Hakugei, and Kinera cables.
Thanks! I’ll go take a look!
Would look dope on the Variations, it’s low resistance and if you contact XINHS you can chose the colour of the hardware too
Okay wow those cables looks cool! I already love the colour.
Will give it a buy! Thank you so much guys!
Which cable would you suggest out of these $40-$50 cable range
Tripowin Altea
Kinera Ace
Tripowin Noire
Tripowin Nucool
Linsoul LSC08
2 pin 2.5mm
I didn’t like Linsoul LSC08 because it was really microphonic
I bought this cheap cable off of Amazon US with no ear hooks to try to fix the fit of my CRN.
It’s actually pretty good for $13. Soft, nicely braided, pretty straight out of the box and looks cool in all black.
https://www.amazon.com/gp/aw/d/B08D6HZN5Y?psc=1&ref=ppx_pop_mob_b_asin_title
Edit: added picture
Hi. I’m looking for a replacement cable for Ikko OH10. Saw a review suggesting Reecho Peacock Spring cable, but i couldn’t find it for sale anywhere.
Is there any other alternative? I’m open to any suggestions.
Thank you in advance.
Thank you
The Spring came with two cable colour options here’s my og cable..
and here’s the one I use now XINHS 4 core graphene…
I see. So in your opinion, is the second cable in similar quality /feel with the OG peacock spring’s cable?
If so, then I’ll probably get that cable instead.
Thanks
Better in both respects tbh…and don’t forget if you message XINHS you can choose the colour way of your hardware if that’s important to you? ![]()
Got it. Now i need to think of what cable color would go well with dark grey-ish color of OH10 shell
. Any suggestions?
Thank you very much for your help. Appreciate it.
