Haha yes about the cable, it looks like it’s a little naked/missing something at the pins. When I had problems with the 2-pin connection being tight I immediately suspected the pins on the cable were deformed since there were unusual-looking. But I tried on another cable and it was equally tight.
The 2 pin shell interface ain’t that bad tbh.. makes a Blon 03 cable replacement look like a cut and shut…
I wonder if they ran into structural problems, where the shell kept cracking apart, if they made a nice & neat indent/platform for the pins, like the Legacy 3 has.
…IN MY POSSESSION!!! Get ready bois we gonna do this
PUMPED!
The Peacock Audio Summer is now listed on Linsoul
Wonder how it will compare
Expletive yea!!! I’m down. I think these 4 seasons will be my last to grab in the hobby above a hundy. Like I’m straight up trying to be a pokemon master here with these
Cool interesting to see where they’re going sound wise with this collection?..I’m using my Springs now to listen to Rush and yeah they’re still a solid rec from me ![]()
I was surprised that they are blue apparently to be after the ocean
Well… i ordered them…
Interesting that they are 2DD instead of 2DD + 1BA
You’d think blue as in blue skies wouldn’t you ![]()
Yeah
According to them its based on…
Summer is created based on the summer blue sea and the wind, the color scheme is blue embedded with shimmering elements. It’s like the glowing sand and sea under the sun
Spring FR
Summer FR
At first glance Summer looks to be warmish-harman/Moondrop style tuning than Spring as the 3k Spike isn’t there anymore
I took the plunge and bought both, I’ll let you guys know when it arrives.
Cool do please let us know your thoughts especially on the Summer as I use my Springs out of choice every day or two ![]()
For current spring owners, according to a few Chinese reviewers, reecho audio equipment is commonly required to burning in, 48 hours and the bass opens up a lot (i.e. across the bass spectrum sounds more balanced), and the mids no longer shouts.
Common consensus is that it is a vocal-centric IEM, Male or deeper sounding female vocal that have more body sound exceptionally good. (They cited 2 chinese artists with jazz-pop, maybe English equivalent would be Adele)
One reviewer compared to Final Audio E4000 but with more bass. According to him E4000 is very good for concert tracks as it has nice stage and makes singers sound good, this one takes it one step further.
I will test these claims once they come in, noting to record my initial impression (no burn in), and letting it run on low volume to burn it in.
Sure thing man
Yepp depressing, still may try to toss some coin eventually.
Tiz odd like Chris said about the size disparity seeing as they were suppose to be a 4 piece set?..Maybe the should’ve picked a shell that could work for all driver con fig’s and tuning and gone from there, it seems they went about it arse about face?
I got the Summer
Still getting used to the sound.
They seemed really hard to drive when i got them at first but after a few hours of music playing they now seem same as spring.
As an early impressions.
I much prefer the spring to summer.
Summer just sounds like its missing something?
The spring are still my go to however I do like that the summer has longer nozzles.
Yep I like my springs too, it’s a solid set for sure
