Lmao I was really keen for the 2.0. I liked the CE white and wasn’t expecting it to be topped, so will be good to read your impressions
Tips arrived. Will plug into my Blon-03 and Tripowin TC-01 ![]()
Edit: I plugged them into the Tripowins (since their shell fits nicer compared to the Blons) and already, these ear tips feel similar to Dekoni’s memory foam tips in my ears. I have a habit of wiggling my ears, and stock silicone tips will irritate my ears. However, these tips have a smooth surface much like the Dekoni tips, and so my wiggling ears are not distracting.
Edit 2: cycling through my library and Sail - AWOLNATION… I don’t think I have never felt a bass rumble happen with IEMs with the Dekoni Tips… Also, the percussion in this song feels crispier, and the piano doing staccato feels like it’s pushing the air somehow.
Edit 3: Nothing for Free - Pendulum: I did AB testing between the Blon and the Tripowin this song. With the Dekoni tips, both IEMs sounded very similar to each other. I was under the impression that the Tripowin was a comfort upgrade to the Blon, but an overall side grade in sound performance. With these ear tips + this song however, the Tripowins end up sounding like the Blons, but more intense. If there’s a FR graph, I’m willing to bet the Tripowins have a pinch more bass and treble compared to the Blons. That small difference is like listening to music in a rave (Tripowin) vs listening on a couch at your home theater (Blon).
Conclusion: I bought the Dekoni tips because of my wiggly ears, but damn. Now that I stepped out of my shell, I think I have to look forward to tip rolling a new IEM now…
Music Mentioned:
I mean, going from the LBBS which is definitely competing in the 200-300 usd range, to a bud that costs like 7 usd. It is kinda obvious there will be (should be) a difference in quality. But the 2.0 is definitely a really good bud.
After eyeing GD3A for a while now. I decided to trust you @Rikudou_Goku and finally made an order. Can’t wait to get my hands on them.
2021-08-06: Faaeal Iris 2.0 review: Faaeal Iris 2.0 - Reviews | Headphone Reviews and Discussion - Head-Fi.org
Rank: A+
Essentially like an Yincrow X6 with less bass and warmer tonality.
Thanks for the trust!
Rankings for the other irises:
Ancestor = A
Grey = A-
YINCROW X6 TRUE UPGRADE!!!
Yeah, you heard me. The true upgrade for the X6 has finally been found! It is by taking the K´s LBBS and applying this PEQ preset:
Low-shelf: 80hz, Q: 1, Gain: 15db
Low-shelf: 250hz, Q: 0.6, Gain: 2db
High-shelf: 7500hz, Q: 1, Gain: 1db
Preamp: -15db
With this preset, I say the tonally gets to like 99,99% of the X6. I went as far as listening to both buds (L = LBBS and R = X6, and vice versa) at the same time to confirm this.
Same ranking as the stock LBBS (S+), technicalities is a step down from the stock tuning, but it more than makes up for it with the tonality.
What is the purpose of using a -15db preamp? Wouldn’t just turning down the volume overall do the same thing?
Basically: it prevents clipping when I am boosting the bass by 15db (technically 17db, but -15db is enough).
More info here: https://www.reddit.com/r/oratory1990/comments/fugckf/why_is_there_a_pre_amp_gain_in_all_of_the_eqs/
(of course, the downside with -15db in preamp mean that you will need a decent amp for it. Otherwise you might lack volume.)
blasphemy!! damnit i cant eq, keep searching
Already gave up finding one without EQ.
Why cant you use EQ though?
use case, use these at work, they don’t allow downloads but i think im gonna pick it up anyway, at least till the Chaconne
oh, so you arent using them on your phone or dap. Rip.
(sometimes I wish that you could “flash” an EQ preset onto the hardware itself lol.)
iphone, waiting on stargate dongle, or usb dac amp for work computer, still great though
Neutron player is on IOS though.
oh had no idea, ill get it and mess, nice thanks… but keep looking lol
I will switch my focus back to iems. The LBBS is that good to me.
My condolences, soon you will have a case of tips, 15 IEMs and be discussing the subtle nuances of IEM A with X tip over IEM B with Y tip…
Enough said haha, still going Chaconne for that build but will be an interesting 3 way compare
