Ok I understand.
Since you asked… I need your EQ expertise on another thing
I wanna try something.
I need a slight tilt up around 100 to 400 to be closer to the target. Basicly, do it more linear I guess. Can you help me with it? ![]()
peak: 200-250hz, Q: 1.4-2,8, gain: 3,5db
Riku are you a bot ?
lol, no. That was just a pretty simple EQ.
Oh and there was that little scrap with another reviewer on another forum a few weeks back. Last words showed you are definitely human
haha, yeah that sure was fun.
Beast. Thanks
Tonality is near identical on the EX800ST/EX1000 when both are EQed to my target.
The difference is that the EX1000 sounds cleaner due to it having a bit better treble extension (airier) and bass is tighter/faster.
Tech is better on the EX1000 though.
The EQ presets are in my database if you got them and want to try it. (@Mufflertape )
Me looking for mids and sub bass be like
well at least it only costs 20 bucks. Wonder about QC tho
Yeah, considering it is an MST driver, that is a steal. Hopefully it has EQ potential if the stock tuning is bad.
I guess I will find out lol.
For QC I can imagine something pulled like GK10. Glue the drivers and call it a day.
Still betting it will sound more coherent , ahah
TBH, KZ and CCA does have pretty good QC…
Only 2 drivers, instead of 3 different types and 5 in total.
So it better be more coherent lol.
Right? He’s simply amazing!
Yikes, that graph does not look promising
Treble looks fine, its a bit reduced from the DQ6 (and uses a different driver). Sub-bass is probably lacking to me, what worries me is that early bass-shelf. It starts at the lower mids, so note-weight might be affected by it.
