XS and XL basically
yeah, but I dont know what do you mean by that sentence…
for my size that fits with the final ear tips
i found all the final tips and it seems the SMALL size is what i like (i THINK its sealing but i dunno how i would notice a difference since all are equally easy to remove and dont sound different no matter how big)… so i’ll either get comply 500 S or spinfits in a small size
Foam are garbage for serious listeners.
yeah lol. I could compromise with silicon/foam hybrid tips, but even then just regular silicone are superior in sound.
Although the comfort with the sony triple comfort hybrids are damn good.
zeos will fight you…
and i dunno if I’m a “serious listener”… i listen and have fun on IEMs whenever I am outdoors like getting breakfast, in the car, or near school… i use open back headphones for “serious listening” and thus I was interested in comply for the comfort and warmth (not just warmth of the sound, the IEMs sound good, but the warm feeling of the tips on your ears compared to the very cold silicone)
This is why I do not trust anything Zeos says when it comes to IEMs.
100% agree.
Silicon for the win no question.
Nah we have evolved to TPE ya’ll, silicone is not as good as Xelastec, but they are not bad. Most foam puts pressure on my ear canal and the body don’t like that… just saying.
Lol, I don’t like the Xelastec.
oh yea… well you are a big doodie head LOL
comfort is amazing with them, sound and cost could be prohibitive, especially cost. I’ve not found any offensiveness with them except they may bring treble more but bass slam is there for me due to the seal. The treble could be caused due to how the TPE is like human skin so similar reflections like the canal gives maybe???
Wide bores usually bring out treble.
silicone is too cold and not as fun to fidget with…
plus the fiio tips seem too stiff and i hate how there are like so many different versions
You are correct, but I wonder about material based reflections too. SCIENCE!!! LOL
also yall are mean on those who want a different material than silicone… i dont like cold tips and every silicone is cold
LOL have you tried the Xelastec tips? Not silicone, so they conform to the ear and heat up.
If your dead set on foam try the Tripowin/Linsoul Foams::
no I haven’t
i am a stubborn motherfucker and anyone who has tried to make me buy something else will tell you so
the fiio was just a lucky moment of my brother buying it if not I would have done the starfield
your cool, I like the tripowins, but they are not ones I use like at all, I just don’t need them atm. But I would choose them for any except the super shallow fitting iems, then something like the Ikko ones.
If that is the case, I would suggest you try the Sony triple comfort tips. They are silicon/foam hybrids, very comfortable and not cold at all.
Not 100% sure if these are the triple comfort, but I have ordered them so I will find out when I get them.
