Looks like typical KZ treble
Unless im getting scammed, ill tell you in the next couple of days
A couple of days? Guess you went with express shipping again on budget sets lol.
Free - coming from Germany 🤷 dq6 will take 10 days
€ 16,61 51%de desconto | Kz edx pro dinâmico fones de ouvido alta fidelidade música esporte fones no ouvido esporte com cancelamento ruído fone kz edxpro dq6 zs10pro mt1
Scamm 100%
Yap, 50/50, either it arrives or it doesnt
It’s 15 bucks so no big deal. I’ll give it to you later for review if you want and they arrive
The challenge if you dare to accept it…
I need a good cable rec for my KZ IEMs, but I want to order from Amazon because I don’t want to have to wait over a month to get it. I’d like 4.4mm or 2.5mm balanced.
Thank you!
Cable A3, thats actually the cable I use on the DQ6. Although it does stick out a bit due to the forward 2 pin connector…
If you want a complete flush connection, there is the Tripowin C8
(QDC connector is what you want.)
if you want more options, I guess @paulwasabii would know more about your amazon options, since he is also in the US.
Brilliant. As always, thank you sir.
Is it? Everywhere I read online it said that KZ was a different polarity than QDC but I’m not sure if that makes a difference.
I got this TRN A5 cable (3.5mm) on Linsoul for my QD6 that’s on it’s way (I pulled the trigger by rec from @TkSilver and i was super stoked that @Rikudou_Goku approves and that @Resolution got one too) ![]()
Dont have that cable, but QDC connectors should work with KZ iems.
I have 3 of those Faaeal A3 cables in 3.5mm and love them. Using on Tea, Mele, and Shozy 1.4. Absolutely a budget win.
I went with the TRIPOWIN cable. I had a bunch of them when I started the hobby so I understand what I’m getting. One of them turned green on me. They are well behaved, flexible cables.
I own that cable. Is not xinhs, but I like it. hasnt been used since it’s mmcx, but I like it.
I do too. I just have never bought any with QDC connections. It should work well for my KZs. Much better than stock for sure. They have horrible cables.
Yeah, ill use stock until i decide they are keepers or not. But i bet stock is horrible
The KZ QD6 wins my worst stock cable award for an IEM.
Worst headphone cable award still owned by HIFIMan.
Will you compare Bravery with GD3A ?
