Seconded! How did you manage to make that???
Something that could not wait another month more or less ? I assume it is cheap ?
Sennheiser CX400BT
https://www.amazon.es/dp/B08CZR3H5W
Oh yes. You in that other rabbit hole. Brilliant !
NOOOOOOO
Just dipping my toes into the water a bit…thats the plan…and it better stay that way…
Good old fashioned gelatin negative mold and UV acrylic.
It was basically a proof of concept that turned out great.
So I will probably do custom shells for all my long term ‘keepers’.
If you want to learn how go over to Headfi thread DIYiems.
Cheers
Have you heard good things about them or taking a stab in the dark?
It is scarbir’s favorite tws, graph looks like the IE900 tuning (so this is like a “demo” of that tuning to me) and uhm… I wanted something to compare to my Fiil T1 lite and it was on sale lol.
Did you receive T1 Lite? How do you like it? I’m not that impressed by them as scarbir is. And I’m annoyed that most tips I have won’t fit in their case
So after reading some reviews, KZ ZEX is basically a slightly different tuned NRA
Not better, but smoother.
Someone even goes as far as comparing B2 vs NRA, they have identical tuning but more bass on NRA, more depth on B2.
this somehow sounds V-shaped, somewhat warm but still peaky and despite the massive bass on the graph, it doesnt sound like it.
But so far…the only reason I havent cancelled my CX400BT order is because that one graphs a lot different from this…
What is that treble gains
They use oval tips, so that might cause some issues with the graph.
Because typically, with a 3k peak like that. I would have died on the spot.
But yeah…I dont know what to say…if this is just shilling or if this is simply the standard of TWS…
Guess the CX400BT will decide the fate of TWS for me. Cuz so far, it isnt looking good…
What gains? CAN YOU REAPEAT? SORRY IM NOT UNDERSTANDING. I’m deaf now by just looking at the graph ![]()
I see, I haven’t had much attention to TWS buds after discovering BTR5 and Q5K, just pair your favorite IEMs with these guys and boom, the only hassle left is cables.
Also I like DQ6, but I feel it doesn’t deliver much slams from the bass, it can deal with fast and quick bass though but doesn’t emphasize them much. Any other budget recs other than the blons?
Damn that graph looks horrifying… I think best bet for TWS is an IEM + BT adapter like TRN BT20S Expert Super Pro Advanced Sound ![]()
Those 2 are like the only budget iems (sub 30 usd) I use…
Yeah…
I am a bit pissed off about it…
Try tape mod, they bring bass to next level
