Asgard 3 master race.
Besides that, it depends purely on mood…
Always that :smiley:
What differentiates the magneto from the electro ?
I haven’t owned either.
The EST that most people think of is the Sonion EST drivers. They have a separate transformer (not sure if thats the correct term) attached to the driver.
(technically, these are electrets and not true Electrostats, the only real ones in iem form is stuff like the Shure KSE1500.)
MST, aka magnestostats.
(Driver from Earbridge, it is a hybrid between a regular DD and a MST, a “2-in-1” driver.)
Dont have that transformer attached and the driver itself is different.
(MST is also an electret though.)
The ZEX/NRA is most likely based on this earbridge driver, a so called “bellsinged” version of it.
That makes a ton of sense, thank you.
It also helps explain how they are replacing the BAs with a single MST.
Although the NRA´s MST doesnt do much…
@Resolution look at what a friend lent me today.
Just started listening to it, had to turn the volume on my Asgard to MAX!!! LOL
If i decide to buy one for me i will need another amp just because of these…
I’ll just leave these here for the teasers.
lol @ 27 dollars for these
Not many reviews out there but ZAS has been reported to lean on the dark side (see PW review for instance) and I believe it since the bass has even more energy than CCA CSN.
So, probably not shouty at all, but reviews are not exactly glowing. Recessed upper mids (except 2k) and lower treble might help rock & metal though.
Here’s mine, at unboxing moment
Nice. My stock cable didnt even left the box. Box is in the bin :joy:
Same, wish they revised the cable and tips, but I guess it’s for keeping the prices cheap.
Tips feel good, but they didn’t seal. I literally just got it, I’ll tip roll later.
Using Final E and DIY Riku’s mod atm with 1/16 foam
Nice cable ! Is it that one ?
I have it on the way :yum:
Yeah, stock tips are too soft for me to seal.
so it get’s a rec for metal, got to jump on the train
I don’t do metal, but they bass is tasty. Fast and slammer. You gonna love it
Yes, it is!
Okay, fuck it, I’m gonna grab a pair of DQ6’s at a local shop, it’s gonna take a while for my Oracle to get fixed
Ordered the same cable for mine a week back… :wink:
I already have one but it’s 2-pin (not QDC) and that doesn’t cut it for my OCD… :rofl:
