So it’s their “Tanya”, I wonder what the tuning resembles. If it follows their usual VDSF target, it may be a similar purchase choice to the Tripowin Lea.
Hard to get an impression of the nozzle length/ insertion depth from their photos, it’s like they deliberately only show the outer face or glimpse from the side.
I feel like Spring tips look great for fit, but I don’t like what I’ve heard of their impact on sound.
they’re the only wide bore i can comfortably wear (unfortunately) besides SS radius deep mounts (not even sure if these are wide bore looking at them again) so they have a place for that in my collection
Moondrop releases Chu, $20 IEMs with non detachable cable
The amplifier turns on last. Before that does not really matter.
But do I really have to? I can’t turn everything on at the same time? Why?
When somebody is in the price realm of monoblocks I expect them to have a decent dac / pre-amp with anti-pop relay.
Do you have to? No, most stuff is designed where it won’t blow itself out on start up (but I’d check the manual to see what the company suggests anyways), but should you still do it anyways? Better safe than sorry imo, esp when you put a big investment into some nice gear. The tyr looks like it has a standby mode, so with these I’d just leave them on anyways so you don’t have to worry about it. In my own setup I personally always just have the dac on, and then preamp, then poweramp (at least if it’s a setup where I have a power amp and pre lol). In a different setup with also a combined dac/pre and power amps that setup just has triggers so it turns it on for me. In either setup I’d really really really really not want to risk having something go wrong and take out speakers or power amps just because I felt like turning things on in a different order that day
This all being said, I would have liked to see triggers on it as well, but I guess schiit just instead wants you to rely on their internal standby and use that
To an extent yeah, I’ve looked into a few power sequencing options as @MazeFrame suggested, but so far as I can tell they’re all huge/commercial rack units, and still don’t fully automate the process (unless I’m just missing the right gear, totally possible)
What im talking about is getting a system of full bore Hifi separates to emulate the functionality of a networked active speaker, where I can kick off roon/Tidal/airplay/whatever and it will wake the whole system from standby, start the amps, recall the last volume setting on the pre-amp and then start playing remotely. With how popular powered/network active speakers are these days you’d think separates manufacturers would want to play well with each other.
There’s a few combos of sources/pre’s/amps that can get this done without:
A. Leaving something on all the time
B. Getting wacky with some arduino/RasPI install
C. basically just being an all in one you put on your hifi shelf, thus limiting the component swapping goal of separates (NAD C658/Masters)
TO each their own ofc, but I just wish more gear supported standards like 12v in/out or we had some newer/more sophisticated way to accomplish linking a system up.
Totally agree. Having been in enterprise operations for many years you quickly learn to appreciate the wisdom of load distribution, power sequencing, and eliminating single points of failure. It became second nature to employ the same techniques (as is practical) into my home setups as well.
Yep yep same thoughts here, and I am more concerned about keeping my own investment safe rather than the companies lol (but I’d still rather not take a hit for either if it’s fairly easily avoidable)
The unboxing of Moondrop Chu
TinHiFi releases the P1 Max! Is it more efficient than its predecessors?
New DAC/amp from Xduoo:
Looks like a balanced Cirrus DAC/Amp rather than a DAP. Specs nicely, the design will obviously be niche.
You are correct! I didn’t look too deeply as I am not in the market. I just got an email from them and wanted to pass along.
Hiby R5 Gen 2 with Class A amp stage, does anybody know the power output specs?
someone said 480MW into 32OHM
not sure if that’s official though
Source:
A bit too much for IEMs, but the more the better haha
The New Nekocake Special Edition TWS with BT version 5.2
