Itās just what happens when you go for a fully differential design, your single ended has to suffer, itās not uncommon on other fully balanced amps, otherwise you also have to design a whole nother single ended amp inside the amp to get good single ended performance which doesnāt make sense from a cost perspective
And as you said⦠donāt need fully differential to prevent ground loops.
I wonder how it compares to the Jotunheim?
Clarification, they seem to have largely the same power output but the Magnius has a couple years of development on it at the very least and Iām wondering if the cost drop from Jot to Mag is a product of years of R&D bringing down the cost
also interested in sound signature differences
Sorry misread what you meant, yeah I agree
Regarding balanced, thereās also just a coolness factor to it for people just jumping into hi-fi. I was (arguably still am) that person a few months ago, and if you havenāt had experience with SE vs balanced, itās easy to overstate or overthink the difference.
A lot of it is aesthetic really. Itās just cool to use the big chunky XLR plug and calling your setup ābalanced.ā I mean, just from a linguistic perspective, being balanced sounds WAY better than being unbalanced, right?
Decided to look at the PCB a bit (if someone could find/take some straight down shots of the PCBā¦)
Is an interesting happening arround those two Op-Amps (LME49724 and OPA 1688 if anyone is interested).
As far as I can tell, the single ended is in paralel with the R+ (or L+) of the balanced.
Buying more than 1000 TI TPA6120A2 (the main amplfier stage in this, as in the RNHP, Topping A90, SMSL sAp-1, etc.) brings the price down to $2.00 per piece, making it cheaper than the LDOs in the power supply of the device ![]()
Good deal or bad deal? lol
To me, good deal.
A lot of hifi-gear makers push the power conditioning to the user. Which IMHO is a garbage practice.
To Schiits partial credit, they have a diode (electronic check valve) in place to protect the device from incorrect polarity barrel plugs. And some capacitors.
Again lacking proper chokesā¦
Edit: Apparantly the Magnius has an AC input, so that āDiodeā may be 4 Diodes in shape of a bridge rectifier.
I donāt expect the power supply to deal with 24V DC to 400V 3 phase, but come on! Some input filtering (common mode choke, Class Y filter Caps, etc.) are neither too big nor too expensive to fit into a >100⬠device.
Reading this new thread reminds me to thank all the knowledgeable people who contribute here, and are so helpful to we who have been helped. THANKS!!!
This is an amp that was made to match the Modius in looks and provide a balanced partner. If you wnat stellar SE perf and are into specs for $99 cheaper get the Hersey for SEā¦BOOM.
The power out for balanced is indeed more for the balanced sideā¦but at 32 ohms the SE is a āmeaslyā 2 watts RMS compared to 5 watts RMS for the balanced sideā¦
WTF overā¦how many cans need a full 2 watts RMS pf power??
To me the SE option is not as ābadā as some stateā¦
This is a world class amp for $199 with full balanced and a āslightlyā gimped SE side it you can call it that.
2 watts RMS is not gimped IMOā¦
Alex
how do you think the magnius will mess with the DROP THX amps
Honestly if this thing performs like a balanced RNHP (same chip as mentioned) it might be a GS X Mini killerā¦
Letās not get unreasonable here lol
Heyā¦for the specs its really closeā¦
So you dont have 15 pounds of billet aluminum in a caseā¦hmmm.
And it doesnt cost $2000 + etcā¦
Understand what your sayingā¦but look at the specs and compare, and do the blind testingā¦
Would guess many would be really surprised!!
lol
Alex
I mean for a world class amp it should sound world class, not only look the part on paper
I havenāt been surprised yet then lol, although honestly I canāt say that I have really heard anything world class outside of a few things (that are unreasonable to own lol)
Understand⦠you have to define what world class is in some objective terms?? Many of these touted āworld classā amps often state their specs or other glittering adjectives etcā¦
So here is a $199 amp touting some really great specsā¦but I do agree its all in the listeningā¦
I will report back next week after some of thatā¦
the best!
Alex
You mean like the Topping A90?
That has 4 TPA6120A2ās in there.
Moar chips = moar better, right?
Specs are meh, Spec Sheets are better, assuming one knows how to read them ![]()
Canāt say that was the case unfortunately lol
I would say, that Schiit has been knocking it out of the park consistently since the Asgard 3/Bifrost 2. Iām going to be very interested what people think about this amp.
Oh yeahā¦didnt want to confuse folksā¦bedside reading 1953 RCA Tube Manual !! or Bob Cordells amplifier design bookā¦
