šŸ”· Schiit Magnius
$1.250 range it appears… My wallet screams at me enough and I try to keep audio related stuff under a budget you know that. Tempting as it is I would have to pass on that. The only amps I have tried with similar characteristics in sound were the IFI brand however, they don’t seem to open up the sound from my experience so far like the LP can. They also don’t make tubes from the looks of things. I could do without the balanced honestly but I like the sound signature the LP brings to the table and that added tube sound is very lovely
That would make things a bit more tempting yeah.
Let me direct you towards the ifi pro ican lol which is in a similar slightly less range used, that thing is packed with features (crossfeed, their good bass boost, tube and solid state modes, and more). I don’t think it’s as high preforming as the fire but it’s way more versatile, but also now going back to a balanced amp again. Ok back to the magnius lol
Just looked it up. Jesus it’s slammed with options. Again though, way outside budget. Wonder if perhaps one of the audio stores has that monster in stock… I would love to sit with that ICAN for a bit… despite the price that thing is a monster it could potentially be my end result I have been looking for if it has the sound signature simiilar to my plat
Agreed back to magnius
Couldn’t help myself. I’m wondering if this might be able to just replace the v280 for me. So far the sound is quite thumpy. Easily drives the Diana v2.
Really solid amp at first listen.
Waiting for more impressions! :grin:
I read a bit on headFi about Jasons approach to heat dispersion on the amp. Whatever he did here it’s , well, cold. Feels like a class D. Even though I think it’s a/b :man_shrugging:?
This is a home run for schiit. I can’t hear measurements, but I can definitely say this thing sounds full and rich stacked on the modius. The 789 (which is the only amazing measuring amp I’m aware of that I’ve heard) sounded thin and weak in many scenarios. I don’t care if it’s accurate, I don’t want my ears to feel like that ever again.
I want to say high gain sounds fuller to my ear but it’s hard to volume match accurately.
Also, can confirm the pot on this is as good as the RK27 on my gs-x mini.
In person, it feels like a heresy/modi stack got inflated to twice their usual size.
We gonna get a Mini vs. V280 vs. Magnius?
FWIW - I feel with Schiit’s products affordable options, High Gain was the winner. Gives you a more pronounced sound signature and makes the presentation fuller.
Your initial observations on heat coincide with the RNHP which I think uses the same chip. This is very interesting.
Pretty sure that’s because schiit reduces negative feedback a bit in higher gain but I could be wrong
That is how I would do it. :smiley:
Possibly. Currently the mini has earned a place in my heart so I’m not certain I can be objective. I probably (this is after I move) will do a stack comparison. It will be unfair but the Maximus stack (that’s what I’m calling magnius / modius) vs BF2/mini.
Shane…we always need ā€˜another’ amp. knowing you though, you’ll just wait for someone to sell one they tested and don’t want anymore, so you aren’t hit with the depreciation :wink:
that’s a funny comment. I know the L30 basically devalued the A90…which is why it’s funny. LoL!
are there any balanced amps with really good SE as well?
I hear what you’re saying, but I am Really satisfied on the amp front, except maybe a tube curiosity I just can’t shake. :grin:
Gs-x mini (character limit)
Pretty much any Transformer coupled amp can do free SE to Balanced conversion and vice a versa, so most none OTL valve and a few very high end SS amps.
You have basically 2 choices when you take a balanced amp and want to feed it to SE headphones.
Throw half the amp away and the associated noise reduction which is what Schiit is doing.
Or find some way to combine the +ve/-ve signals, the options are basically another op amp stage to combine, or use an air gapped transformer.
Throwing 1/2 the amp away is probably the least audible, the opamp solution would probably end up with the best measurements, and the transformer coupling can remove a Cap from the output which is considered desirable in some circles.
are you saying the Magnius is lacking chokes or that lacking chokes is part of taht endemic problem of vendors pushing power conditioning to the user?
Most of the time the balanced will sound better on a balanced amp, but most of the higher end amps have good sounding single ended outs just because you are reducing the quality of an excellent amp balanced to very good when used single ended
