Puh,can try it again with the other dacs you have ?
I hope you donāt have sell it.
So test it and report this problem is the same or not.
When is the same maybe the Usb port have a issue on your pc.
So when possible try the modius on a other Pc. So you can check is the Pc or the Dac.
The same with other dac.
So you can better say who came the issue.
Maybe when the Usb port on the Pc is to old Usb 1 they gives problems.
But i think is not this.
Your bios think oh usb Port is connected i start with it a find no Data,bios stop the progress.
Other possibility is the driver from Schiit for the modius have a issue.
Try plugging the Modius into a powered USB hub or behind a hub with switches.
Could be that the start-up-current it pulls results in the motherboard failing a self test.
Edit: Or try hooking a power supply to the Modius, it has the port for it.
Hello,
When it works fine on your Laptop and the modius make no problems.
I think the problem is the Pc who a issue.
Possible is the Usb driver are maybe old.Check it for updates.
When possible deinstall the Usb driver from the Pc and make a restart.
After this windows must be update the actually driver.
Simple example i have change the Pc from my Media room to the Living room.
The pc from the living romm are newer as the the other.
I put the Wlan repeater inside an after 5-10 min the Pc crahsed.
I habe changed the Mouse,ect.
Later i replace the Wlan repeater and all works be fine.
I used to work for the IBM PC company in hardware and software compatibilty and ran into these
types of issues ALL the time!!
First thing we did was to make sure all the updates from all the vendors were up to the correct levels.
Its now mostly done in the background now with the latest OSāsā¦but there still are glitchesā¦
To check you should be able to go to the vendors wesbite and support page and find your laptop pc and bios etcā¦this may or may not resolve your issue but its one less thingā¦
Seeing how this works on other pcs, then definitely there is an issue with your Omens hardware or softwareā¦dont know if you apply all the latest W10 updates as wellā¦another good thing to check.
uninstall and reinstall usb drivers?.. It is clearly not the modius but is the Omenā¦If it works fine elsewhere then it has to be⦠Hp in the past has had some flaky driversā¦
