đŸ”¶ Sennheiser HD58x Jubilee
i removed the mod that was included in my used purchase and they sound a decent amount better
 more bass but not to the point of ruining the crazy highs on 100 gecs
 i still rn prefer my M50s because
  1. they are colder on my ears (i love the pads on them)
  2. the M50s sound kinda brighter which i seem to prefer (there is a bit of muddying in the vocals that i dont like that much)
also the dekoni pads are AMAZING for hip hop but not for any other genres like indie rock
You know, if you really want something that has more bass possibly than the M50x, it is possible you might like the Nighthawk Carbon. No need for an amp. Probably pushing your budget at $250, but you wouldn’t need an amp on top of that.
since treble doesnt bother you too much maybe the meze 99 noir/classic/ neo might be up your alley. not as bassy but definitely better mid performance the akg k371 is an option. fidelios x2 hr for pleasant bassy sound many including myself thinks its pretty unrefiuned but for current asking price its pretty damn good
I’d suggest just listening to them for awhile like a week or so
 I find v shaped headphones give you that wow feeling initially but something like the 58x can grow on you
also the one problem im starting to have is in the comfort
 i can’t listen to these all day because it feels tiring
 maybe i’ll adjust though
I love the 99 Classic’s for an economical closed back. The are my go-to for on the run, but I prefer the sound of the HD58X’s at home. The Noir makes it even more attractive price wise.
They do have a pretty good clamp. Even on my used pair.
the clamp does kinda hurt
 as well the pads aren’t that comfy
They will get comfy AF. :stuck_out_tongue:
For the clamp, if it’s too much, you can just “extend” the headband as much as you can and diminish the curve of the metal part of the headband a bit.
(I’m sure there’s a better way to say that in english but pardon my french lol. I hope you understand anyway.)
I find the pads very comfy, but if I was going to wear them all the time I would have to “stretch” the band.
I have a few questions. First, what kind of dekoni pads do you have (velour, sheepskin, etc)? Second, when you say foam mod do you mean something like this?
Third, do you have stock pads? The stock pads are the best way to listen at first since it is the “intended” sound and you will have a good baseline to compare. The dekoni pads are very comfortable to me, but can make the sound worse. The velour pads bump the bass a bit but can muddy the mids for some people, but a mod like the one I pictured fixes that (at least for me). Like I said, if you have stock pads give them a try. Also I would recommend ONLY using the HD58X for like a week or two, then switch back to the M50s and see how you feel.
  1. velour
  2. yes
 i removed it
  3. yes and i’m using them
Cool, thanks. So I would stick with the stock pads for a while like I said. From what I know about the M50s, they should be a rather aggressive sounding V shape while the HD58X are a rather mid forward signature with good extension in both the treble and bass. I imagine you will notice the difference with some more listening. Like others have said, the HD58X are not “WOW!” headphones, they’re just great headphones for a great price if you want that mid forward sound.
i guess i have a preference for a very WOW sound
 mostly because music is getting boring and not just because of burnout
so someone on r/audioadvice reccomended i get the BTR5 as my laptop DAC
 should i get the sennheiser balanced cable and if so where can i get it
So first of all, the sound signature alone, are you enjoying it a bit more now? Do the vocals still seem too dirty?
And I can’t remember if you would want a balanced for more juice from the btr5, hopefully someone jumps in with that
they sound better now
 i enjoy it
I have the Hart Audio Cable kit for mine and using the balanced 2.5 on my BTR5 and the full sized Balanced on my 789 definitely make a difference. (to my ears anyways)
Gotcha, I know they require some power to get better but wasn’t sure if the btr5 would be good enough in single ended of not. Thnx! @duke86fan so there you heard it, get balanced as to where I’m not sure myself lol. I can vouch for the 58x really improving from the already great sound when paired up with an amp
