I would say it’s more isolation is what you would want tbh, if you listened quietly I would agree though but no isolation
Sweet, I hope it works out
Thanks, further down the rabbit hole we go…
Take your time and pace yourself and appreciate what you have as you go
I think that is a message that should be iterated more often.
It’s my moto these days as I discover cheap and good and keep buying ultra budget gear. And I flood my time trying $2 earbuds after $10 iems
Chifi is a stupid addiction
I dunno, sounds more sustainable than the standard HiFi hobby!
On the subject of cheap IEM’s - SoundMagic E10’s are freaking awesome.
I think there’s an E11C now.
Nah you end up spending the same amount on a bunch of mostly mediocre shit
I’m right now trying to find a mh755 killer interns of value for money
Too many chu Fi fans buy cheap shit constantly surprised the shit sounds decent look at the price tag and over hype it but when compared to stuff I already have it’s virtually useless cause… Like it just sounds that much better
Amazon have them for £8.72 in black.
But… £6.39 in PINK.
Which ones?
OH
Now I understand - sorry - you are trying to find a cheaper/better set.
No I’m looking for something better that provides a better price to oerrmance ratio and better build
Also only confirmed confirmed legit seller that has it in stock is kanoya on eBay
So, 250Ohm DT770’s now on the way too. If I’m not keen, I can send them back, of course.
Cool, let us know if you like them! They should be a little less sibilant and the bass should also be a little tighter, as well as having a bit more detail. The wire might be a bit large and heavy, but personally I think that’s good so it doesn’t break.
Will do! After listening via the Atom again, I am pleased with the purchase. Everything just sounds fuller, and… tighter. I like it. Should start seeing some big differences with the 250 770’s. Now, I can now compare more setups too.
