Ayyyyyyyy look at that lol, that is correct that it’s just a dac, it is a better dac than in the fiio k3, so quality will improve further.
Gotcha then
Gotcha then
Yeah I have a holiday home where it wouldn’t be practical to be carting around the JDS + DAC to power them - but the K3 would have it’s place there with the 80’s. That by itself still isn’t a terrible sound. Or, in a pinch my Sony’s are decent enough for that use too.
OK if the Topping is only £65, then I’ll likely pick that up shortly.
Gotcha, just wondering though, how much can you get a fiio q1 mk2 for (it should be the same price)? That’s a portable dac amp that sounds almost the same to the k3 if you wanted something smaller and more portable. The fiio btr5 is also pretty awesome but it doesn’t have a dac out
And be careful with the topping, as there is a fake topping floating around under the name of Aimpire AD10 or something like that
You could if you want, sell your 80s and save up for a more portable pair of headphones.
Well the K3 isn’t all that big - it replaces an E10K that I used before in the same setting - so that’ll work nicely.
Noted on the fake topping. Thanks!
Not a bad idea ![]()
I’m just saying with the q1 mk2 it can go battery powered and can fit in your pocket and connect to your phone to act as a dac amp, so if you wanted to do that you could as well. It can line out as a dac too. Just if you were inters ted in something more portable
Roger - I’ll have a think about that. I never use my cell phone for audio so wouldn’t have crossed my mind previously.
Ah, then never mind then
I appreciate the alternative ideas though. I’m starting to realise there are more options out there than I previously even considered.
There are some really dumb yet awesome portable setups that can ask as a desktop and portable solution lol. Lot’s of stuff out there. And iems can be fun too
Oh IEM’s are nice. I have SoundMagic E10C’s I bought years ago for a daft price, and they are pretty good!
There’s also the BTR5.
Have you tried them on the amp lol?
Er no ![]()
10 characters
I was thinking about that, but he couldn’t use it as a dac well because it doesn’t have a line out
Perhaps see what happens lol (it won’t blow up or anything)
Gotcha. Makes sense.
Yeah if you run massive power into IEMs they usually sound amazing.
Just be careful on the volume lol. It depends on the iem how well they handle the extra power, but you are putting it on a higher quality amp
