Long boi?
Aside from a fictional porn star name, what do you mean?
Long boi?
Literally long. Ok, got it. ![]()
There was an inference⦠![]()
Ya-ya. Iām slow, but I get there eventually! ![]()
Thatās a pretty classic amp lol, I remember trying it before and was just surprised by the dimensions (sounded good too)
Yeah I want to build one for the Hybrid Amp Feel since itās a DIY Amp, but I canāt find a seller that still sells the Torpedo III Board. Thereās an official site that sells the Torpedo I Board but idk how similar they are in layout and I have no idea how much of a difference there is I vs III, since I never saw the internals of the Torpedo I, I canāt make inferences on how much more a III is quality wise.
I might call the company directly once Iām done with my amp and see if they can sell me the III board + components or if the I and III board are identical/very similar so I can buy the I board instead on their official site and buy the parts myself later.
Huh, just a quick realization from the Phonitor 2, while the main front output is Unbalanced 6.35mm, the back outputs can support a balanced headphone (Says it on the Back itself), so with a 4-Pin to Dual 3-Pin adapter, the amp can be run balanced. Awkwardly, yes, but balanced nevertheless.
I donāt mind however and I could probably make a Dual 3-Pin to 4-Pin adapter, make it long enough to be lead to the front, then (Using Audiophile Grade Silver Laced Non-Inductive Inductive Gold Colored Vibration Isolating Waterproof See-Through) duct-tape the 4-Pin Output to the side of the chassis, and Voila, Balanced Phonitor 2.
You can do that, but it can be pretty sketch lol. I would just stick to the unbalanced
Well yes, it WOULD be, but I am utilizing Audiophile Grade Silver Laced Non-Inductive Inductive Gold Colored Vibration Isolating Waterproof See-Through Duct Tape for this application, and I thank you for considering the possibility of Sketchyness, however it is under control due to aforementioned method of application.
The unbalanced out has a lower output impedance than if you used the balanced output on the back for headphones, just something to note
Oh, huh, well I do have IEMs, so the low impedance would be nice, besides I prefer the 6.35mm Jack anyways, just the feel of it honestly, well that and the practicality that all my other amps use 6.35mm, so itāll be WAY easier to go from one amp to another, less hassle in needing to change wires/use adapters.
Ah! Good ol AGSLNIIGCVIWSTDT. What would we do without it?
Welp, I finally bought the Phonitor 2. Itās B-Stock but seems to be in working condition. Hope it turns out well.
Edit: Super Excited for the VUs, they come with a complementary amp which is nice I guess.
Hell yeah VU meters lol
Hope you enjoy it ![]()
Ngl Super duper excited, super giddy, and it probably arrives this week too.
Curious to see your thoughts, especially on the VUs
